Split tilt deck trailer winch roller
1190R
I'm adding a winch to my split deck tilt trailer to load disabled videos
I've see rollers on the leading edge of the tilt deck as seen below
Any idea where I can get one of these?
510ebl
Southern New Jersey
Thank you 510!
You're better at finding stuff on the internet than I am
I'm a little shocked at the price, however, and may be taking slow84's advice and fabbing it myself
You are welcome.
Once you have the pillow blocks/bearings and collars (all McMaster Carr stuff) the rest is likely just cut and assemble. Your local steel supplier may have all the components on hand.
1190R
You are welcome.
How to fab part at tip of arrow?
jrsavoie
North east Illinois
I have yet to comprehend why anybody would buy a split deck tilt.
I will only buy a tilt, but never a split deck.
I have seen people get in trouble with them .before.
That and a beaver tail on the end of a tilt. What is That supposed to accomplish? It makes the start steeper and loses flatbed length - no gain other than manufacturing expense.
ZX3ST
STL
I'll agree with you on the beavertail, never seen a tilt bed with one, but split decks can have advantages.
Since the axle must be positioned behind the center of gravity of the deck (to allow gravity-tilt), a standard tilt will usually have the axle(s) placed further forward. I've found this can make it a bit more difficult to get the proper tongue weight.
Split decks, at least the ones I've seen, generally have the axles placed further to the rear of the trailer, since they don't have to balance the weight of the entire deck, only the tilt portion.
Example - My old flatbed car hauler had a standard tilt deck, and I had to place the car REALLY far forward to get the right balance. It really defeated the purpose of having a longer deck. Having the axles 6-12in further to the rear of the trailer would have been better. But if they were, it wouldn't tilt without power assist ($$$). A split deck would have helped me here. Yes, it would have made the approach angle steeper, but I needed additional assist ramps anyways since the car sits so low.
jrsavoie
North east Illinois
The power assists really aren't that terrible expensive. Check out hullporter trailers in Iowa.
My 20' just had a hand pumper.
SundayFunday
Mn
That's basically a thick washer with OD = ID of tube and ID = shaft size.
Buy some 3/16 plate or bar stock and cut to closest size with hole saw.
Grind to fit and weld it up.
It wont have to be perfect, so you could even free hand it with a plasma or saw or grinder.
zkdiesel
chicagoland cornfields
Cause you use it as an equipment trailer with attachements in the front non tilting part
1190R
Thanks Sunday
