xJoey Dubsx
So last year I found this Cycle Country plow on Craigslist in Canton for $20 for my Warrior, which some of you may remember... Came with everything, but one piece for the manual lever, middle rod, and U bolts..
Last year I found U bolts for it to mount to the frame, a threaded rod for the pivot/quick release, then let it sit in my backyard.
Winter's coming so decided to mount it up and start working on it...
First is getting Winch Mounted, 2nd is blasting it, painting it, and some powdercoating..
How it looks like as is now.........
Well then my work put the 4000lb Smittybilt ATV winches on sale for $129.99...
Decided against using the manual handle, atleast right away and picked up a winch!
Now all I have to do is a make a mount for the solenoid, one for the winch plate to mount to, and then one for the fairlead to go to the DG Bumper.
I don't want to have it fully permanent, so I can ride and have fun, but if it's muddy out I would like to use it, but mainly for winter plowing.
It's sweet since it was only $130. Less then my employee price even.
Comes with the mount, fairlead, handlebar mounted controler, hand remote, hook, hook strap and wiring stuff.
They even have the 3000lb one for $100
But yeah, I know I'll get the "Warriors are only 2 wheel drive" deal. I have a wide but short drive way, so worse case I'll haul *** out and push snow once I'm out of the garage.. We'll see.
