Spot Weld Chisel - any recommendations?
driz
Northern NY
Don’t they make a special drill bit for those things. I never did many over the years but for occasional use an appropriately sized regular bit worked well. With a chisel method I’d be more worried about bending or distorting the panels .
Beau Nugget
NE Kansas
You can find a special bit called a spot weld cutter. Just find one the same diameter as the welds, and you’re good to go.
txvwnut
Bedford, Texas
A spot weld chisel is actually to be used after drilling the spot weld since you won’t get the entire weld sometimes. They’re called a spot weld chisel but they’re more of panel separator. I use a Steck after I’ve drilled the spots to help split the seam.
Elsinore13
Spot weld drill bits like this are what you seek. 8 and 10mm for automotive, mostly 8mm.
https://www.belmetric.com/spot-weld-drill-bits-c-415_645_647/db37470-spot-weld-drill-bit-p-3623.html?zenid=egd0hsrbhgsap8h0r25guvca86
Wamsutta
Amarillo, Texas
I use a Starrett automatic center punch to keep the #40 wire gage drill bit centered. Then afterwards I use a larger size drill bit to separate the two sheets of sheet metal.
eyeball
Pairing up Blair Spot Weld Cutter with a Streck Seam Buster my son and I removed over 100 spot welds from a 1970 Nova during a full restoration. We had little to no damage to the underlying panels once we mastered the process.
The chisel is sharp on the front and right curved portion. It can be struck from the rear or the flat left side.
Both are available on Amazon.
joe_padavano
Northern VA
I'll second the Steck chisel. I have their Seambuster version that goes in an air hammer. It's great, if noisy. Be sure you have the spot welds drilled correctly, as you can start damaging sheet metal pretty quickly with this think if you don't pay attention.
NYBODYMAN
NY
This ^^^
SM Racing
Huntsville, AL
I have a couple of these:
isb cornbinder
I have mixed success with chisels. Equally, I have had mixed success with special spotweld drills. I think the chisel and spotweld drills work well together. Don't rush it.
You will never disappointed with MAYHEW. Buy the best drills.
BE AS GENTILE AS YOU CAN.
Steve_P
Vim makes a set of striking scrapers that is similar to the Snap On above; but I think that they are even thicker than the Mayhew splitters. I bought the Mayhew, but they are sharpened on both sides, like a traditional chisel. I ended up just using an old paint scraper since it was much thinner. The Steck looks like it's only sharpened on one side? Anything that's going to stand up to moderate use is going to be ~3mm or thicker. If you do a good job drilling, a thin paint scraper with the steel thru the handle will work.
afazz
Pittsburgh, PA
Is the Steck Seam Buster thinner than something like the Mayhew Dominator Weld Wakker? The blade on the Weld Wakker is about 3mm thick. I wonder if it will be hard to wedge between seams.
Yes, it is thinner than the Weld Wakkers. It also has a more shallow bevel ground from only one side which helps control which panel gets wrinkled and which panel remains true. I have Weld Wakkers and they are not as useful for this application because they are so thick, and the blade is relatively blunt, you typically make a mess of both panels. I also have the Snap-on strike through shown in the posts above, and even a PB Swiss thin chisel but they're all too thick to work effectively for separating autobody panels.
I have Lisle and Steck, both are great.
Somewhat related, I have found that belt sanders (Dynafile, 3M, or even the cheap ones) are faster than drilling. Blair spot weld cutters are the best if you're drilling.
