Spray can storage
IslandOlds
Any unique storage out there for spray cans such as paint, Break free oil etc? Looking for some ideas....
Always_Thinkin
Illinois
The attached photo was an idea i came across and plan to build.
crewchief888
NW indiana
i keep all my spray boms of paint is a small metal wall cab,
BC, pent oil, ect is in a couple of metal spray can trays hanging on the wall, extra cans are in another large metal wall cab
i dont "stockpile" cans of anything, i buy what i need for each project.
:beer:
Jmatlock88
Here is yet another version of the spray can storage cabinets. Although I have not yet mounted mine on the wall, it's the same idea. I built two sets with doors that open away from each other. I also added some molding to the doors, magnetic catches, recessed hinges, a two-tone effect, and large pulls. I also used dadoes to mount the shelves.
DynoDave
I built this for items used frequently. Paint, and other products used less often go in a cabinet.
liquidh8
Shippensburg, PA
I use a large double door metal cabinet, floor standing. I try to only buy what i will use up pretty quick. I also like to keep the cans protected from things, like sparks/flames/etc. So having them in a cabinet is nice.
My flammable storage locker isn't real big enough :mad:
rslaback
Westcentral Wisconsin
My solution is so simple I can't believe how well it works. I hate the wasted space I get when I put them in rows and I hate not being able to see everything there if I put them all on shelves. My solution is to put them wall to wall in my cabinet in an offset array. To use a can I just pull it out of the matrix. The other cans are essentially locked in place and stay where they are. Then I just slide the can back in. If I have lost the cap I write the color on the lip of the can.
FF_Chevy
Nashville
Maybe not the best idea considering the sheer amount of spray cans needed... but definitely the most awesome idea! :eyecrazy:
38Chevy454
Cincinnati, OH
I have the lowest budget solution, I use old beer 6-pack holders. Then put the holder on the shelf. The holders are short enough you can generally see the label enough, and I tend to put similar types together. No picture and none required.
eborcim
Central, MO
:thumbup::thumbup::thumbup:
rockranger
I cut these on my plasma table. Uses 1/2" emt for the shelves. I got a stick at home depot for $1.84 a few days ago. This was my first version. Version 2 I changed to a little shorter so it holds standard cans better and less angle.
Untitled by dresselhausfc, on Flickr
I used a self taping screw in the end to keep the emt from sliding out.
