Spray foam cost?
kota4bye
I want to have the ceiling of my 40x40 shop sprayed with closed cell. What should I expect cost wise?
purplezr2
Central MN
A dollar per square foot per 1" thick.
Example 40x40 is 1600sqft. As priced above it would be 4800 for 3 inches thick.
Honestly I think it makes more sense to do spray in on the walls were there is less space to get insulation in and blow in in the ceiling.
K
kota4bye
Pole barn, there isn’t anywhere up there to blow in. I want to stud my walls for osb before I spray them.
Ecosta777
I got a quote to do between the floor joists on my kitchen addition which was built on an existing concrete pad attached to the house. It wound up being like $1200 for 120 sq. feet. Which works out to about $2.50 per sq. ft per inch (4" thick). May depend on your location, and different contractors will vary a little.
wanderer
Closed cell is pretty expensive. My large home with open cell was $10k. My guess is that your going to be about that number.
skippydoo
Sussex NJ
40x30 scissor truss's 2 pitch inside , 5 pitch roof , 13ft walls with one 12ft wide garage door and one man door. 2 inches in walls and 3 on the roof, $7800 in NJ for closed cell
Jon_E
Southwestern Vermont
Had a pro price out my entire garage, 24 x 36, 13' overall wall height, 9/12 roof pitch. Was $8000. I did most of the job with recycled polyiso board and DIY foamed the surface for about a buck a board foot.
Marctrees
TX/LA border - Toledo Bend
Kota - Geo location ????
Under roof deck/ gable ends use OC... approx 40% cheaper per R than CC ... 4" thick is around $1.30 - $1.60 / sq ft
Same OC material in walls you will be covering.
Marc
K
kota4bye
Marc
I'm just west of DFW
yeldogt
The cost of the equipment has to be factored into the job -- small job is going to be a bit more. Same with location -- my area has many closed cell guys -- so, it's actually cheaper for some jobs vs a few years ago. When I did an addition a few years back -- was expecting a higher price .... my guy was able to link it with another small 1/2 day job.
Need to make sure it full weight and thickness -- factoring a $1 will get you in the ballpark
I do 4" on new ...often with renovations that's not possible as the walls are 2x4's. It's so superior IMO -- I don't even think of other possibilities
coalminer16
MN
Closed cell for a 30x40 with 15 foot ceiling at the wall edge with 2 inch on the walls and 3 on ceiling was close to 10k. Cash discount.
coalminer16
MN
Closed cell is R7 per inch and is a vapor barrier.
dcg9381
Austin, TX
Texas, 40x60x16 - About $5k for 3" of foam, average... Open cell.
It looks like the installers bring this in a "drum" - for me, they probably did a little better than 3" and used the whole drum.
yeldogt
Both are blended products
purplezr2
Central MN
Should have noted close cell.
They also came in a drum here.
