I'm looking at putting in 3" of closed cell foam in the next month or so. From what I can tell, while expensive, it should really seal up my building. Since I have 6" deep walls, I'll still be able to put electrical in later for the interior of the shop. I do need to get the exterior outlets and lights up first.
Regardless of what type of insulation you use, you should have all the electrical rough in done first.. inside and out.
Sent from my SGH-I747M using Tapatalk
The stuff is amazing!! I had 136*F difference from the metal outside to the inside of the foam last night. -10F with 40mph winds (-50F wind chill) blew my mind..:
I had the stuff sprayed in my floor joist box sills in my basement and the quote says 3-4'' sprayed but I can say the stuff is pushing really 5-6''. It comes out of the gun so fast that the guy spraying cant really keep it under 5'' effectively from what I saw, just JMO.
At some point I will be stripping my walls and having foam sprayed in, I wish it had been in the budget when I built it.
I may just buy a used set up and do it myself for just the cost of the foam, I would do a few more projects as well and then sell the equipment.
I had a friend do his shop and new house this way, but he bought new and the dealership that went with it and is now in business doing it, but for some reason he doesn't want to haul his equipment from Idaho to MN to do my job.
I bet the stuff is amazing but what's more amazing is that you had the interior of your shop up to 126F!!!!!
Obviously wind chill is not an actual temperature but a girly, "feels like" temperature.
I'm going to go read your build thread. I'm interested in your water filter too.
Check out my building thread. I did 2" of closed cell (3-5" more like in most places) on my entire shell of my new building. check out my pictures with my infrared heat gun (post #108) The stuff is amazing!! I had 136*F difference from the metal outside to the inside of the foam last night. -10F with 40mph winds (-50F wind chill) blew my mind.. I had frost pushing through the panel seams of my 2" insulated garage doors. CRAZY!!
It's expensive.. but it's one of those pay early (insulation) or pay later (utilites) things. LOVE LOVE LOVE SPRAY FOAM.
I even used it to spray the ground and then covered my boiler lines underground for my wood burner.. 0 snow melt and it's only 12" in the ground. (post #27)![]()
You might want to look into correct application temps for closed cell foam. I know somwone who installs this and his opinion is that its too cold to get a good yield. I take that to mean the air bubbles are smaller and may affect R value along with using more material to get the same thickness of foam.
Rembmering to when I had it quoted, s/f was about $2800 MORE to insulate my shop.
If I cut my heating bill $100/month, which would be almost half compared to standard R19 walls and lots blown in ceiling, it would tak 28 HEATING months to return my investment. December, January and February are the only real heating months here. So ten years before I see a nickle back. Wow! And I doubt that I would save that much. Most of my heating loss if from opening the door to move a project in or out or thawing a vehicle....which is a big heat sucker.
3pedal,
If you plan on leaving the spray foamed walls exposed (uncovered) for awhile, I highly recommend you have the installer add the fire retardant to the mix. Most spray foam is flammable.
fiberglassing the inside of foam.... is kidda like putting the vapor barrier on the outside of the building.....depending on where you live, Bad idea
First post (I think; I donno - I've been registered here a while; may have talked about my generator install a while back?)... Oops - yep - my 10th post... yay me! -- too bad I forgot about the other stuff I posted; getting old ***** sometimes!![]()
I'm almost done having a 36x32x14 downstairs, 36x20x9, pitched (taking into account the 4' knee wall) upstairs garage/rec room. The upstairs will be finished, and I'll be using the spray foam to insulate the roof/upstairs, then finishing with sheetrock. This will have the added benefit of giving insulated storage space behind the knee wall (do the math; I think the roof is on a 9/12 pitch - or something close). Downstairs in the business side of the garage, I'll be utilizing fiberglass in the walls. The contractor I'm using on this build mentioned the foam as being superior, as he used it in a very similar garage/loft he built (I think it's slightly larger, maybe 4 feet or so in length) and rents it out. He heats & cools the upstairs (Central NC area) with about 9000 BTU of mini split, and says he can easily keep it comfy. Researching the heck out of the foam, and his word that he can put it in for me at only 1.5x the cost of fiberglass, I'm going that route, even though my other choice would be to save the installation money and put fiberglass in myself. The thing that sells me most on it is that it seals everything up so well, but I'll still be able to "breathe" in some fresh air from the garage.
Had my 38x40x16 pole building sprayed the best thing is how well it seals up the building no drafts. Even on windy days no drafty which equals no heat loss.
