Square D QMB Saflex
xxxlmark
Can anyone give me direction on removing a section form the middle of the panel board? I have searched the internet and found very little on how the sections are removed. Any help is greatly appreciated.
Norcal
Why do you want to remove a fusible switch from a panel?
X
xxxlmark
Yes, I want to remove a fusible switch from the middle of a panel. I don't have any pictures to post.
ard
IMO if you are looking for instructions on the internet, you probably need to call a pro.
This coming from a 100% DIYer.
Especially of you cant take a picture, provide an explanation, describe what else is in this 'panel', etc, etc
LXCam
I don't understand your question. Do you want to modify the bucket or remove a bucket from the panel board.
X
xxxlmark
it is 3 phase and I have to remove and replace a fusible switch. I assume that removing the 2 screws from each side of the switch will allow me to pull it forward. I am unsure as too how the switch attaches to each leg. I wish that calling a pro was an option but finding someone willing to service 3 phase in my area is impossible.
where do u live?
what voltage are u dealing with? If 480v, u need to be absolutely sure about the procedures you are doing, unless u can shut the power off to the panelboard first.
Did u look at the link i posted?
LXCam
Those buckets if under 100amp are held on with at least four screws, 2-3 on each side of the bucket the thread into the vertical frame. The stabs to the buss are spring clip type. So once you have those screws removed it will pull straight off. Just make sure you have the panel completely de-energized please!
X
xxxlmark
it is 480v and I am having the electricity disconnected while I do the repair. I looked at the link but confused about the "Blow-on Connections".
I am located in Tightwad Mo and yes that is a real place.
X
xxxlmark
Will disconnecting the main power supply de-energize the transformers? there are 2 liquid transformer that step down from 480 3ph to 220 3ph and one that steps down form 480 3ph to 220 1 ph.
LXCam
Well that's damn near impossible for us to say without seeing either the panel schedule or a single line diagram. But considering you said this panel is 480, then I'd say there's a real good chance this panel services those transformers.
But you say you have liquid filled transformers? That's not the norm. How old is this service and is this panel your only 480 panel.
X
xxxlmark
yes this is the only 480 v panel. It was installed about 18 years ago with parts from the 1950's.
LXCam
Do you only have one meter? Also you can follow the conduit that feeds those transformers and if they come from the 480 panel.....;)
