75gmck25
I have a Square D QO 30/40 200 amp panel that was installed about 3 years ago by an electrician. It was permitted and inspected as a 200 amp "heavy up" from my old 150 amp panel. I assume the box came from one of the local electrical supply stores. The panel is now full (30 circuits) after they finished our kitchen remodel, but I now want to add a double breaker to feed a garage sub-panel.
I want to move four of the existing circuits to two new tandem breakers, which will then open up two slots. Those slots will be used for a 60 amp breaker to feed the garage sub-panel.
Are there certain positions where the 10 tandem breakers can be installed, or would they work in any position? There is so much wire in the way in the box that its hard to read any of the labels on the inside of the panel itself, if the labels explain which positions are for tandem breakers. The panel cover has nothing about the location for tandem breakers.
Thanks,
Bruce
Thanks,
Bruce
