stainless food prep table in garage
cparcell
hillsboro ohio
So I realized that stainless food prep tables are not to expensive and should make a nice work bench. Can anyone think of a reason not tp use a couple 96 inchers along the wall.
Playwme
The Lucky Country Down Under
I've got a whole pile that I've removed from various commercial kitchens and plan on using them for just that.
Not only were they not expensive, I got paid to remove and "dispose" of them.
drmarkr
Tucson
I have one in the woodworking room. 96" with a 5 inch backsplash as well....excellent bench.
C
cparcell
hillsboro ohio
Dp you guy's worry about them denting easy and I
the ones im looking at are 1200 lbs rated and 625 on the bottom shelf. But at 200 for 96x30x35 ss bench, I doubt i frame and put a decent top on a conventional bench same size
slickstysix
I'm looking for a nice 6 foot with a backsplash. All the ones I've seen so far are pretty lightweight. They wouldn't hold up to a heavy beating. I anticipate having to bolster the underside with planks and build or at least reinforce the legs/frame.
Aaroncl
I tried one a few years ago. I think it was a 6 footer. The top was nice and the frame was simple but the joinery between the two was horrible and rendered the bench useless too me with-out modifying it. Make sure the table is assembled on its legs when your shopping around. I'm sure there are some that are more heavy duty than others.
Disturbed
I have a stainless steel front counter out of a McDonald's that I use for a workbench. Its about 12 feet long with shelving underneath it. I beefed up the mounting and shelves but it works great and I am very happy with it.
SRD9Boss
East Hartford, CT
I have and use one. Works excellent. I use it for assembly/cleaning etc. No problem with denting and super easy cleanup - spray with brake-clean and wipe off.
Gixxer603
I have a small one on wheels. Mounted a bench grinder to it with a couple rubber grommets to lessen vibration. I can wheel it outside when I use it so it keeps the shop clean
Lvnspeed
I have one also. I found it on Craigslist I paid $30 for it its is 8' long and 3' deep with a 5" backsplash. I love mine
Vegaman_Dan
Pacific, WA
I would advise bolting a piece of OSB or plywood under the surface to help prevent dimpling or denting of the surface. These were made for food prep, not transmission rebuilds.
I would love to have one myself to use as a hobby bench.
C
cparcell
hillsboro ohio
Im looking to try and find some used ones in my area that arnt the cost of new one just yet but everyone is like mines a main brand and you cant buy this 800 dollars new etc
Hammer1963
Kentucky
I have one at work and at home. Both are used for general assembly work. One of the nice qualities of a stainless steel is they are impervious to most common garage chemicals. Great for mixing auto paint or cleaning parts too
MScott
Eastern Ontario
I have a stainless steel work table but mine is a medical one so food prep is not the only source. I bought it at a garage sale from a senior citizen lodge that was undergoing renovations. IIRC I paid about $20 for mine. Quite sturdy too and came with large locking caster wheels.
Waggoner72
Cabot Arkansas
I've been looking at getting my current workbench covered with a sheet of stainless steel. 8 feet long, 2 and a half wide. Want a 2 in backsplash. I can't find any place that will do it for less than 450...... You can buy these new prep tables for like 200 for the same size. I don't get it.
C
cparcell
hillsboro ohio
That was my point aswell, but womeone mentioned the 200 dollar ones had a very thin top when I was point out to a guy selling used ones in Lexington ky
6t7gto
bedford,ohio
I picked up mine from a scrap yard. It has a sink in it and I added a pump to the faucet and use it as a parts washer.
Sink drains into a 5 gallon bucket to recycle the parts washer fluid back to the faucet.
GTO
NJ,FL
I've got an eight footer myself,I got it free from large professional kitchen demo that we did,could have had a second one,but could not fit it my truck.
don long
southern california
I have a few tables that I have picked up from a used resturant supply house
This one is 16 feet long and very heavy
I also have one in the paint room for mixing paint and it is very easy to keep clean, a little lacquer thinner and no paint spills
sberry
Brethren, Michigan
I have one for paint. Pics are probably after I first built it.
wnstwolf
New York and PA
As mentioned if you can get one with a sink they make great teardown benches with built in parts washers! got this one for $50 all it needed was new legs that were actually inside under the sink in a bunch of nasty goup. A quick stop to the do it your self carwash and a few tack welds and I am set.
I also have a 8' top only with 6" back splash. Added a few 2x2 stiffiners and placed it on top of two metal base cabinets. Gret gereran bench but not for "beating the **** out of things" cant beat a good butcher block top for that work!
