standard 3 car garage?
SoCalGarage
San Diego, CA
Anyone on here have a standard 2+1 garage?
I dont have the room for a xtra building but wondered what folks have done with what they already have.?
ie: cabinets, lighting, wiring, air lines, etc.
post up what ya got.
thanks,
Doug
S
SoCalGarage
San Diego, CA
Oh no this is fine-
I just wanted to see what others have done with a similar setup.
Theres no way to fit a lift in this garge the heighth isnt there.:(
This garage is attached to my house, its not huge and seperate like the others have on this forum.
I also lack rafters anymore so storage is at a minimum, so Id like to see what others do in that situation.
thanks,
Doug
Craig Balzer
Colorado Springs
Doug
Not exactly sure what you are looking for -- hope these will help.
First two shots show the exterior of the garage so you can see the arrangement of the bays. The 2 bays nearest the house are actually used for cars. The third bay, the smallest/shallowest, is being used as a dog kennel. Don't ask.
The interior shots show the cabinet system I installed this last summer. The tall cabinets are essentially to get clutter out of the house and free up closet space. The cabinets above and below the workbench are my play area.
Not big enough for major, long-term projects but gives me enough space to play. The two bays are deep enough for basic auto tune-up/repair.
Plans call for construction next spring/summer of a 30x78 out-building on my 3 acres. The building is designed in thirds: 1/3 for major item storage (lawn care, patio furniture, etc); 1/3 for kennel/stables and 1/3 for my auto hobby shop. This will accomplish two things: will free up my 3d bay for use by a car (dogs move into their own digs) and my 30x36 shop will easily hold 2 cars (3 cars once I get a lift).
THEN, we go back and complete the shelving/storage system along the two walls of the third bay. That will balance the appearance of the system and double the storage space in the attached garage
Hope this helps -- ask any questions
Craig
foo king zo6
newyork
SoCalGarage said:
Oh no this is fine-
thanks,
Doug
Those garage doors look like there high all u need is 7 to 8 ft clearence.. :rocker: for a nice 4 post lift...if not good luck
Craig Balzer
Colorado Springs
Doug
The Thing belongs to SWMBO. I have a friend in Denver who can rebuild VW engines with his eyes closed and garuntees them to be leak-free; carbs or webers. But -- my wife says "no dice". The current engine is a hybred between two different engines and leaks worse than my Jag. Its the 3rd or 4th engine in it and the body needs work.
But my wife loves it the way it is. She has 6 horses and keeps two of them across the road at a nieghbors place. She uses the hood of the Thing to move hay, feed bags and stores a saddle in the back seat. She calls it her Ranch Car.
I'd love to play with it and dress it up; rebuild the engine, but -- "it runs juts fine the way it is".
That's OK woth me -- more time and money on my cars.
Craig
69lkmno
San Diego - Oceanside
Here's my 3 car garage. The picture with the shed is where I have my compressor. Gives me more room for storage and keep the noise away.
snorvet
Northern Illinois
here's my 30'x32' attached garage:
as far as the goodies:
cabinets: none - I have all storage in my detached garage
electrical: only 110volt outlets - about 8 GFCI all on 12-2 wire 20 amp breaker
lighting: now remodeling - adding add'l fixtures - will end up 6 - 4' 4 bulb fixtures
flooring: bare now but will epoxy this summer
walls: will repaint
lift: none since ceiling isnt high enough
air lines: none
nvmygtz
Vegas
I like the shed for the compressor, I want to do that with mine, how did you plumb it, copper?
How much is the noise cut down, any problem with excess heay build up?
Like the 69 also post some more pics of it under the free parking section :3gears:
69lkmno
I used the Garage-Pak 2 bay kit and just added a couple more elbow fittings. As far as noise, I can still hear a little bit of vibration but not to the extent being annoyed by the noise.
32roadster
okla
3 car
socal
you might try a kwiklift since you have a low ceiling.
www.kwiklift.com
I am Danny, the owner of Kwiklift, Inc. in Tulsa, Ok.
We sell a ton of these lifts and the guys love 'em.
We also sell 4 posts, if you have the room.
Not trying to do a big ad campaign here, but, if you get a chance check us out.
You will like it.
