Both the "Product Information" and the "From the Manufacturer" state that it is an orbital disc sander. Where did it say it wasn't? First one only mentions the sander, 2nd one mentions the sander + kit.
Product Description
CPT7200S Features: -Compact and lightweight for easy access in tight areas. -Rubber molded palm grip for added comfort. -Adjustable speed regulator to match the speed to the job. -Two-finger throttle for easier control and less fatigue. Pad Size: -2" - 3". Product Type: -Orbital Sander. Dimensions: Overall Product Weight: -3.3 Pounds. Overall Depth - Front to Back: -10.5 Inches. Overall Width - Side to Side: -10.5 Inches. Overall Height - Top to Bottom: -3.5 Inches.
The CP7200S Mini Random Orbital Sander kit is part of CP's new Smart Series (Small Area Repair Tools). Designed to be used on small or tight areas instead of using larger sanders. Kit includes a mini random orbital sander, (1) 2-Inch and 3-Inch backing pads, (10) 2-Inch 320, 400 and 600 grit sand paper, (10) 3-Inch 320, 400 and 600 grit sand paper and spindle key packed in a heavy duty carrying case. Air Consumption (CFM): 21, Speed (RPM): 15,000, Pad Diameter (in.): 2 and 3, Random Orbital: Yes, Variable Speed: Yes, Side Handle: No, Vacuum Ready: No, Air Inlet Size (in. NPT): 1/4, Min. Hose Size (in.): 3/8, Case Included: Yes, Tool Weight (lbs.): 1.5, Tool Length (in.): 4 1/2
