Steel building
EFFIGUY
Im looking for help in purchasing a new steel building, can anyone recommend a good building ? I just cleared land in Vermont for a 75X100 shop which I plan to do restorations of cars and old equipment.
There is so many buildings advertised that I don't know what to pick.
Thanks
Rich
sberry
Brethren, Michigan
Its a challenge. Some have real dealers, others have more a diy plan. Most come with engineered drawings for your area. 75,, or 80 x 100 is a good size, can turn around in it. Mine is 80x80 and the only thing I miss about it being 100 is more running wall space. Door location and floor plan is everything as well as consideration should be given to utilities etc.
I have 2,,, 80x80 shop and 80x100 storage.
nehog
Jaffrey, NH
I'm still very happy with my Rockford after four (or is it five?) years. Zero problems, I did build it myself, but they will do turnkey as well. Tell them I sent you (as a happy customer) and perhaps they'll give you a discount? (No, I won't get anything.)
sberry
Brethren, Michigan
Not only that,, there are countless features and options. Its like a lot of things that one goes thru so rarely in life its easy to make mistakes. A lot of them hard to fix. All the way from site planning.
I saw a university extension plan or 2 that are probably better than nothing but I can say for sure from looking down on the drawing the human traffic flow is wrong and would be modified,,, or not,,, some don't change,,, but had some real areas confused and cluttered,,, the last thing I want to walk past every time I enter is a drill press with shavings.
I know this, did it, ha, seen it done and lived with a lot of self made problems. Once I really realized I could do makeovers and move things from the first place they landed it made a difference. I can still feel some change I make wont be "perfect" so I can do it again if it matters.
Hence,,, the big stuff, the shop itself, electric next to real demands as much as possible. You become an interference fitter once its under way but I try to get water feed, electric stubbed up to the other side of the building or anywhere I know I got to go under or over. Put another panel or 3 in the place, it allows for welding service anywhere and reduces a huge amount of branch runs and having or wanting to compensate for voltage drop and resistance in piping,,, is easy to lay under as floor and hard and slow to hang.
E
EFFIGUY
Thank You everyone, I feel much better with recommendations. I am going to look into some suggestions and will be sure to post all construction photos.
