Steel Ceiling Color - Glare?
therpmguy
I am at the point where I have decided to go with a metal ceiling but my main concern is the color. I have decided on white to improve the lighting but I am not sure which white to pick. My local choices are 30 gauge bright white indoor ceiling panel or polar white 29 gauge exterior siding which is more of a softer white and slightly grayish. Both are made by American Building components. Initially I was set on the bright white to maximize the light but I am concerned that the bright white may have too much glare. This is a hobby garage and not a body shop or paint booth. I would really like to hear from those of you who have metal ceilings to get your thoughts on your color choices and if you would pick a different color if you could do it over again. Thanks in advance
mitusa
SW Oklahoma
I've got white R-panel on my ceiling....eight foot ceilings with fluorescent lighting. I don't think the bright white would be a problem.....you prolly won't be looking at the ceiling much, and as you get older, you will need more light.
T
therpmguy
Thanks for the quick response. I like to do a lot of work in the garage but I also like to just unwind out there sometimes. The glare it my biggest concern. Great site by the way. I have been browsing it for years but just registered. All comments or suggestions welcomed.
jomobco
Denver, CO
I've got a pic of the interior white on my home page here. Both with lights on and off. It works great for me.
mitusa
SW Oklahoma
I don't see a pic, John. But mine is R-panel 26 gauge from Muellers. I would suppose it's exterior grade...20 or 30 yr paint guarantee. With about 6-8 inches of loose cellulose insulation on top, between the celing and the roof.
I found the pics.....looks a lot like mine. Mine is a eight foot metal building. Nice job on yours.
NUTTSGT
Northern Central Ohio
Honestly, I couldn't imagine getting any glare off of a ceiling. While I may be wrong, I'd probably just go with the cheaper guage and put it up. Save the money to use elsewhere.
Red05GT
ohio
We used the bright white panels in our workshop to get the maximum light reflectivity.
Glare has not been a problem and we have 8- 100 watt incandescent bulbs in porcelan
fixtures in a 20 x 30 shop. We used the bright white panels floor to ceiling on the walls
as well, 10' ceiling height, no glare. Just our experiences.
KPSquared
Wetaskiwin, Alberta, Canada
Are you staring at the ceiling a lot or something? I don't think glare is an issue. We used a high gloss white paint in my friends shop and it just helps reflect light down.
T
therpmguy
Thank you for the responses. I will probably go with the brighter white since it will save me about $100. There are plenty of other places I can spend it. Thanks
T
therpmguy
Well, I ordered the 30g in bright white and it will be here next Friday. I will try to post Pics when it goes up. Thanks for your advice.
