I plan on putting a 5/16" steel plate on one of my movable workbenches but that particular workbench is topped with two half inch layers of osb board. I used the osb for a little added height and because it was what I had laying around. Can I just adhere the steel plate to the osb or should I replace it with mdf or plywood? The osb bench top hasn't warped and the plate weighs over a 150lbs. I also plan on beefing up the bench since it is going to have the additional 150+lbs of weight. Any input on this would be appreciated.
