I went and visited the local water tank manufacturer this morning as i knew they were having a carpark sale.
I was first in line and came across the perfect tank right at the front. Some idiot had drilled the overflow hole at the bottom. They are going to poly weld it shut before i pick up.
5000L slimline for $1100
Also scored a 60LMP 800w water pump for $250
They sold me a cover for the pump for $58
I also picked up a 20L container of Euco Diamond Hard which I'll use to coat the shed floor. It was roughly $200
Sent from my SM-G920I using Tapatalk
. They shut schools and said do not go to work if can avoid it due to the heavy rain predicted. I would be worried about flash flooding. So if it is business as usual for you then stay safe.
