Today I welded up a mounting bracket for a window style AC unit. It's going above the back door so it's close to the main work area and out of the way of racking.
I had a fun time working out the compound mitre cuts for the diagonal braces on the bracket. I needed to do this so that the AC bracket aligned with the additional bracing the shed has around the door frame. It should be enough to take the weight of the AC unit.
Speaking of the unit - I've got one of the largest window style LG aircons that was a freebie so I'm going to give it a go in the shed even though I'm aware it'll struggle to cool the entire thing.
I'm hoping it's enough to take the humidity out and take the edge off a stinking hot day in QLD.
Next step is to cut a big hole in the sheeting and slide in the box.
Sent from my SM-G955F using Tapatalk
