Stihl & Husqvarna chainsaws
freudianfloyd
Nowhere
Finally something I can talk about. As a guy that flips saws as a hobby, maybe I can provide some insight into saw brands from my experience.
Stihl -
1. Bring a premium for some reason, new and used. People assume all Stihls are pro saws, even the little MS170.
2. Stihls are also much easier to work on for me. I'm sure others will say that Husqvarna is easier, but I disagree.
3. They are plentiful and used parts are easy to come across.
4. They are great saws, plain and simple. If you know how to start them, and use non-ethanol fuel, they will reliably start every time.
5. Can find used ones everywhere (yard sales, swap meets, on the curb by the trash, etc.)
However...
1. As mentioned above, dealing with B&M stores to get parts is annoying.
2. OEM parts are expensive
3. They are susceptible to flooding unless you know the starting sequence.
4. Farm Bosses are NOT pro saws. You would be surprised how many people think they are.
5. Stihl saws leak, I have 40 saws in my garage right now, the only bar oil puddles are under the Stihls.
Husqvarna -
1. They seem to cut above their weight class.
2. Parts are generally cheaper and easy to order online.
3. They don't seem to leak bar oil
4. Much better anti-vibe than Stihl
5. Can buy homeowner grade saws in more places.
6. They just feel much more engineered, fit and finish is much better than Stihl.
7. Typically less expensive for a comparable saw to Stihl.
However...
1. Dealer support is few and far between (atleast in my area) and when you do find one, they seem to be more interested in selling the big Husqvarna equipment, not supporting saws.
2. Pro-saws are rare in my neck of the woods.
3. Saws take a little more time to sell than Stihl.
4. Some homeowner grade saws are in fact Poulans, and thus not worth fixing. Jonsered are also Poulans now FYI.
Echo -
1. Good homeowner grade saws. Their top-handle saws are amazing.
2. Very reliable.
3. Relatively inexpensive, which makes them perfect for homeowners
4. Just good all around saws.
However.....
1. Terrible resale compared to Stihl or Husqvarna.
2. OEM parts are extremely expensive if you can find them at all.
3. There is a reason the pro loggers and arborists don't use them.
4. Pain to work on (old ones anyway) New ones are not much different than Stihl.
5. Typically underpowered for their size.
Dolmar/Makita (Very limited experience with these)
1. Great saws, when you can find them.
2. Parts can be ordered online.
3. Good resale.
However.....
1. Dealer support at least in my area does not exist. I don't even know where a dealer is located.
2. They rarely go up for sale in my area used, so I don't get to deal with them very often.
3. Again, loggers and arborists typically don't use them, there must be a reason.
As far as my favorite, Husqvarna for all the reasons mentioned above. But love Stihl too.
Xcursion88
Are you guys even pronouncing it properly? 🤣🤣🤣🤣
I've owned one stihl...
Zero Echo...
Owned several HOOSK VARE NAH
Or HUESK VARE NAH
My kin liked Echo...was an ECHO dealer...
The only one I had issue with was a leaf blower and it was Stihl.
I've since swapped that for the big H
Xcursion88
Stihl -
However...
Husqvarna -
However...
Echo -
2. Very reliable.
However.....
3. Good resale.
However.....
Excellent information
Downwindtracker 2
BC
Here in BC the forest industry was a huge part of our economy, well over half at one time. So chainsaws were important. Chainsaws were invented in Germany and after the war German patients were free. So the chainsaw was developed in BC, we had the big trees where it was really needed. . Electrolux (Husky) bought them out and closed them down. For a long time Husqvarna was the Brand, now it's more Stihls. But it will still will bring on a Ford /Chevy debate. I have both. I also have a Poulan on my quad., after a few years when it doesn't start, I toss it and buy another reconditioned one for $149 Canadian. They barely start when new, as it is.
Davefr
OR
Stihl -
However...
Husqvarna -
However...
Echo -
2. Very reliable.
However.....
3. Good resale.
However.....
Great summary.
I'd add a couple:
Husky uses an air injection system to expel chips from reaching the filter
Both Husky and Echo use primer bulbs. I've never seen one on a Stihl. If you store a saw dry, primer bulbs sure make starting them easier.
Stihl pro grade saws are easier to work on. Easy to replace fuel line and a much simpler impulse design.
Then there's the inboard (Husky) vs outboard clutch (Stihl) discussion but it's really personal preference.
freudianfloyd
Nowhere
Great summary.
I'd add a couple:
Good point. I much prefer the stihl inboard clutch. It makes replacing chains easier for sure. I also like that stihl clutches can typically be removed with a 19mm socket whereas Husky saws require a special tool or ingenuity, or a hammer and punch if you get lucky.
Ton ton
Page County,VA
I'm a Husky fan. But currently run a MS 261 . Gutless piece of junk. It feels like something to toss in the dumpster @ the end of the day. I have run beside my neighbor on the same log with his Husky. His saw has the same cc as the 261. But he can crush me performance wise. I hope Stihl makes something better than a MS261.
WinMod21
I had a sweet little Stihl 026 Pro that I foolishly sold before we moved across the country, along with a 8500 watt generator, just to reduce our overall shipping weight. Have more than once wished I would've kept the 026 Pro. 😞
And now wish I would've replaced it with the MS 260 Pro; but I decided to save approx $100, and settled for the MS270 Wood Boss. It's decent, but just over a pound heavier, with no decompression valve... which unfortunately makes a big difference... the older you get. :eek2:
WinMod21
I thought the MS 261 was supposed to be a fairly nice saw; 3.06cc - 4.0 bhp - only 10.8 lbs :unsure:
Johnny Generic
35 miles NE of Pittsburgh, Pa.
I have a Husky 44 that I bought in 1985 to clear a area to build my house. Lot size 1.25 acres of mid to old growth oak and maple. use saw approx 1-2 times a year for cutting up fallen trees branches. Never tuned carb. Never been in the shop. Replaced chains and bars. Clean air cleaner after each use. After each use drain tank and run dry. Few squirts of carb cleaner, then on the shelf. 3-5 pulls to start up every time. Just saying, Johnny Generic
Ton ton
Page County,VA
As another poster said, every 7th Street corner has a Stihl dealer on it in Virginia. I have a friend who is a Stihl dealer and he doesn't appear to be cracked over Stihl because they have a hard time keeping stuff in stock recently.
jhelrey
MN
I looked at Stihl (used many) and just couldn't pull the trigger due to price and availability. I bought the Echo 590 because I have their Echo PB770 and it's been fantastic. I wanted one can of mixed gas using good oil. The price was right, the power is great, and the bar is thick. 60CC and a 20inch bar. Did what I needed it too.
By the way, the M12 Hatchet is great as well!
rusjack
Ontario, Canada
Two years ago my dad gave me his 1989 Husky Special 50. He bought it used in 1992 or 1993. I think the special 50 was the saw that became the Rancher 50. He told me how to choke it, pull it, and it started right up with old gas. He and I have never had an issue with that thing so far. I've cleared out lots of trees on my property and cut tons of firewood, and I love it. 15" bar seems oddball, but I found a few clearance Oregon chains and a guy who sharpens them dirt cheap, so Im not sure if I should move to a bigger bar.
Ive used my in-laws Stihl saws, and the newer ones I've used feel like toys. MS170 and MS270, I believe. The 270 is much, much nicer than the 170. I feel like with the size and weight of the MS170 I could just be using a battery powered saw and have the same "feel".
Although, there is an old "Made in West Germany" Stihl 034 AV in the barn that needs a new cylinder I might work on to repurpose and give back to my father in law. It was his dads and has been on the bench for many, many years.
Rinspeed
NY
Just to be fair both those saws are light duty consumer saws, they feel like toys because they are aimed at homeowners who want to cut up a couple trees once in a while.
WinMod21
Actually, the MS270 doesn't feel anymore like a toy... then my Stihl 026 Pro felt like a toy, which was a very popular lightweight pro saw. Even though the MS270 was rated as a 'Farm & Ranch Saw' when it was available, it's actually fairly heavy duty, 'cept for being a bit under-powered on the power-to-weight spectrum.
Holden
I’ve had about 4-500 saws thru my shop over the past 15 years. Started picking them up cheap, rebuild the carb sharpen the chain and sell them for a few bucks back when I had not a lot of cash substitute teaching. As far as the stihl vs Husky debate goes it’s simple. Both have made legendary saws and both have made junk. As a rule I don’t bother with the consumer grade saws, the 400 series huskys sold a Lowe’s or the consumer stihls. They aren’t bad but with 40 saws in my shed now I only run pro stuff. Also I have a lot of older Poulan and Homelites, in the 70-80s they made some great hi performance stuff Poulan did till the early 2000s (3450, 3750, PP330). With any tool I buy the best I can afford. My favorite Stihl saws are my 10mm 044, 038 magnum, 034 also have a new 661 I haven’t tried yet. Husqvarna 266xp, 365, 42 special, 372xp.
heres a 2171 Jred I just rebuilt, new oem top end, K&N filter and TOTAL BAR.
We have lots of saws…more not pictured2A997522-14AC-4501-8EE5-9A927EB1FBF2.jpegF254E40F-4E23-40CE-996D-7EF60C05B1DA.jpegE6DF19C3-A8A2-4B7B-A44B-8FA90530097C.jpeg7137308F-AE18-4A89-A3F3-32FA7D65FA28.jpeg06A511FA-6D31-4188-8281-C2DCEEF0D0B7.jpeg5FDA797F-5509-4E23-9400-9DD88A594B6F.jpeg
Dakotadadv8
Dakotadadv8
Good information. Looking at professional Stihl 462 CM, great looking machine. Should help with any storm clearing projects along with Stihl Pro Splitting Axe (another thread perhaps). Not bias but I like to stick with Stihl. Too bad COO is not USA.
Kscardsfan
The Little Apple
I’ve run both shades of orange at various times in my life and I can’t say that they’re different enough to matter in 90%+ of the time. The biggest deciding factor for me was dealer support, which gave Stihl the nod, at the time we didn’t have a Husky dealer within an hour and half drive of us, but had 3 independent Stihl dealers in town who were all pretty knowledgeable and friendly.
freudianfloyd
Nowhere
Great collection. I love my 2171, it's a beast.
You should post your saws up in the "Show Me Your Chainsaw" thread.
Davefr
OR
The Stihl 034 is a great saw. If it needs a new top end, throw on a 036 top end kit and you'll have a saw with a really high power to weight ratio.
huzaen
To summarize, which brand do you recommend?
Ton ton
Page County,VA
I have problems with the cable tearing on a MS 361 Stihl chainsaw. The cable with a spring around it if I remember right. It broke for the 2nd time in 13-14 months. It connects the grab handle to the saw. I have never had this problem with a Husky. Stihl is all about making money on their replacement parts in case you haven't figured that out yet.
Banjorear
Essex Co., NJ
One thing I do for my Chainsaws is to only Run Canned fuel.
Either the Husqvarna XP premix, Stihl Motomix, Or I will buy a Gallon of VP Racing 4 cycle fuel and mix in a bottle of Amsoil Saber at 50.1.
I do this on all my Saws, Leaf Blowers, and string trimmers. Maybe a little overkill, but I like the piece of mind knowing when I need to get my saw and go to work, it will fire right up.
I do the same.
Rinspeed
NY
I always thought canned fuel was way over-rated, just running the thing out of gas is very effective. Of course, I have multiple two strokes and no way in hell am I paying $28 a gallon for fuel. :rolleyes: If it works for you that is great though. Locally we have non ethanol fuel but it is only 89 octane and I only buy 93 for the tools and toys.
chainspor
Stihl -
However...
Husqvarna -
However...
Echo -
2. Very reliable.
However.....
3. Good resale.
However.....
I am a stihl user. And I am very happy with Stihl. I do all my work with the products of this brand
ATC
VA
I just did a bunch of research on this subject over the last few months, as I was about to buy a larger replacement for my MS180.
In the end, I wanted the Echo 620. It seemed to be the best bang-for-the-buck saw on the market right now. But, the Echo dealer here didn't stock them...they stopped at the 590, but could order me one.
So I headed over to the Stihl dealer and flipped a coin between the 261 and the 311. The MS311 won out, and I brought it home. No Husky dealer within 40 minutes of me, so I ruled them out.
All my friends are Stihl nuts, so at least I stayed on their good side.... :badteeth:
I still love my M18 Fuel too...
Goosedowner
I've been running stihls since the late 70's and I bought a Dolmar 6400 4 or 5 years ago and I'm very impressed with it.
Ton ton
Page County,VA
Those chainsaw sharpeners in the link above are scarce as hen's teeth around here. Yes, I have talked to my local Ace hardware.
Robinson1
Kentucky
Its a toss up.
Stihl is easier to work on but Husqvarna is easier to get parts for.
Husqvarna has better air filtration.
Stihl has better bars and chains.
It really comes down to dealer support.
Rinspeed
NY
Its a toss up.
Not that it will matter to most but a Stihl will always have a much better resale value than a Husky.
