Storing screwdrivers
Roast Beef
Manchester UK
So, I would like to store all of my screwdrivers nice and neatly in an order I can recognise. Unfortunately, opening and closing the drawers a couple of times and they roll about causing disorder (yes, I am very OCD).
The snag is, I have quite a number of screwdrivers, mostly SP Swiss and other specialist drivers - none of which are going to readily fit into the blown poly trays that Snap On drivers come in.
Anyone have any suggestions?
Thanks.
rslaback
Westcentral Wisconsin
Thanks.
how do you feel about foam shadowing?
bcoke
Pawlet Vermont
I realize you have OCD but look at all that square inches of wasted space!!! a liner that would keep them from rolling to much or spacers that would keep types separated [flat-philps-robertsons etc] would be more efficient in my view ,plus no slamming drawers......bobbycoke
rlitman
Long Island
I have a drawer with slotted handles in the back, points forward, and phillips handles in the front, points backwards, shanks overlapping. The next drawer above has other drives (robertson, torx, frearson, JIS, etc).
But cut foam and formed trays, as much as they waste space, do have their uses. At the end of the day, it's obvious what is or is not missing. Can't say the same for my drawers. If you're in a business where FOD is a problem, you can understand why this practice is prevalent.
oldldh
Fairhope, AL
Your OCD is of the "Amateur Variety"...:wtf:
You buy the EXACT number of screwdrivers...:thumbup:
That...
Will fill the drawer COMPLETELY!!!:lol:
Then you'll have "Professional Grade OCD"!!!:evil:
rslaback
That's a drawer I did for work. This is my personal screwdriver drawer.
malibu101
Walnutport PA
You mean this istn't the right way to store them?
That's my way of storing them too.
That...
My disorder will not allow me to waste so much drawer space for so few tools.
:willy_nil
monster1
My OCD makes me store my drivers from front to back, not side to side so that they will not roll when the drawer is opened. But I have a screwdriver that is too long to fit from front to back. What shall I do? :lol_hitti
DSM_PWR
Illinois
I use these in my box. I have quite an assortment of drivers as well. Makes pretty good use of drawer space, and everything stays put when opening and closing drawers.
http://www.amazon.com/Torin-SDH15RT-Magnetic-Screwdriver-Holder/dp/B00DS3GK0A/ref=sr_1_1?ie=UTF8&qid=1454451746&sr=8-1&keywords=magnetic+screwdriver+organizer
I use that very same Torin rack. I believe MTS is the original manufacturer but it's cheaper to buy the Torin labeled one. These are also available at Lowes if you want to purchase from a brick and mortar vendor.
nickb
southeast FL
I use Epco drawer liner and stack them front to back and back to front with the shafts in the middle. Ive had them in the same spot for a year and they dont ever move unless i make them. Nothing else even compares.
Sent from my LGMS323 using Tapatalk
drink
Confused State
I just stick mine in a drawer and put them back where I got them from. Opening the drawer without a big yank helps to keep them in place.
nickb
southeast FL
This is before and after. I had the most trouble with the 1/4 extensions. Now I can slam the drawer all day and not have anything move. :)
lonestarky
Lindenhurst IL
If you don't want to foam/shadow the drawer, consider a thin strip of Styrofoam to stab the ends into to keep them from rolling, front to back is easiest though.
Sent from my XT1254 using Tapatalk
nikerret
Kansas
I plan to make a wood block, for all of them. Still collecting, now. Just got my Proto metric nut drivers!!!!! Looking for a deal on the 11 piece SAE, next. Then square and hex and I think I'm good.
R
Roast Beef
Manchester UK
This is the answer, perfect - until a new driver comes along that I HAVE to have!
I will find someone who does this local to me. For now I guess the Torin plastic rack will work as a stop gap solution.
Thanks everyone for the proliferation of ideas.
smedly
Savage, Mn
Several magnets with a strip of steel over them.
IKEA makes a pretty inexpensive magnetic knife holder that would also work
wkndwarrior29
NorthEast
Shadowing is actually very easy to do, this was my first project which took less than an hour and three yuengling lagers. Google kaizen foam.
gtlaw
Got the sunex rack too. It didn't help out my screwdriver drawers at all. It just became a reason to buy more stuff
pendragon1998
NE Georgia
I am thinking of kicking my screwdrivers out of my box and onto a wall board like some of the above pics. They aren't exactly precision tools in need of protection.
RBFD415
And let me guess, they're ALL number #2 Phillips?!
