Stubby keys (torx and hex)
Leaflessshadetree
Don't ask.
Stubby torx keys.
I'm looking for a set of stubby torx keys similar to these. https://www.wiha.com/en/produkte/l-...ball-end-13-pcs-in-titanium-silver-40979.html
Anyone know of similar keys available in the U.S.?
While I'm posting I'm looking for stubby hex keys as well and have found these Bondhus:
http://www.bondhus.com/bondhus_products/tool_categories/l-wrenches/briteguard_stubby.html
http://www.bondhus.com/bondhus_products/tool_categories/l-wrenches/stubby.html
Any preference of the bright or black?
Any better options?
Htscheg
Buffalo, NY
Both Bonhaus and snap on make these also, I have both and work great, Snap on also makes a ball end torx set too!
franzdom
NC
PB Swiss makes very nice stubby hex keys but I don't think they make stubby torx keys.
The Wiha look fabulous, I would hold out for those.
ocloc24
For the hex I have both the brightguard and the regular black and I've grown fond of the bright. They wipe down easy and resist rust/corrosion well
woody1407
Stubby torx keys.
Any better options?
I use the bondhus stubby allen wrenches everyday at work. Metric and SAE. I have the black oxide ones and a few guys have the bright ones. Both work just as well as the other.
L
Leaflessshadetree
Don't ask.
amazon carries Whia torx keys both in long and short versions.
But apparently not stubby. At least I haven't been able to find them.
Actually they do, but the largest is T25 One that I could use often is a T27:mad:
those are really nice
I could get them in NZ but I'll have to convince myself that they are $200:shocking: nice.
:headscrat (and I'll have to figure out the additional cost of the high security display case).
Finky198
North East
I have the bondhus stubby sets in bright and I am very please they were my first set of decent hex keys. The Stubby is super handy. I have sets of reg snap on keys and folders that I barely use but they each have their purpose...
If I could only have one set bondhus stubby are the best of both world.
Low profile, Extra long, with a ball end. It really covers most situations.
Finky198
North East
^^^ I concur I have 6 Stihl saws and that are used constantly and very rarely do I need to take them apart for any reason other than to blow the dust out of them.
Leafless is right bars and chains, fresh gas and quality oil a clean plug and filter. Store em dry and they will run forever, well a really long time .....
Wamsutta
Amarillo, Texas
The Bondhus hex stubbies are awesome, but I don't know if they make them in Torx. You might have to go with Wiha for the Torx.
franzdom
NC
The question about Stihl wasn't because they break down but because T27 is super common on them, even to change air filters.
Finky198
North East
Maybe some older saws, but not anymore I can change the filter on everyone with no tools whatsoever... if you can’t fix it with the bar tool you’ve got big problems :lol_hitti
CR888
'The bar tool' is a scrench which depending on what type may have both 3/4'&1/2" nut drivers and on the other end either a flat head, T-20, T-25, or T-27. The pro grade tools usually allow access to air filter by hand or possibly clips that need a flat head or 1/2 turn locking nuts that need a flat head. Generally its the homeowner saws that require torx to remove shrouds. But in any case if your cutting wood a scrench and basic tools come in handy to tighen/remove bar nuts, adjust chain tension and dry a flooded spark plug. As for a stubby torx, a cheap trick I did was order a pair of acetate stubby screwdrivers from China on eBay, the red and green ones that have 1/4" bits in them and remove the bit and put wiha T-27 bits back in. Only cost like $1 for a pair delivered and there good.
L
Leaflessshadetree
Don't ask.
Actually the T27 application I'm think of is on Harley Davidson motorcycles. I have to remove the floor board to get to 1 (of the 5 screws) that hold a cover to change the oil or adjust the clutch. The floor board bracket aligns perfectly with that screw.
CR888
You actually change the oil on a Harley...I thought the way it worked was if no oil is leaking on the floor, you know its out of oil & needs topping up.
xin
ARKANSAS - NWA
I wish the whole TORX series would go away they are such a pain and the tips break regardless of brand.
Like the worst design on earth but it sure generates a LOT of business from tool vendors.
WhiteElder
I've a set of stainless stubby hex from Wera. Have not had them long.
Tho i think they only offer metric hex on stubby.
Sent from my SM-J727V using Tapatalk
Oops phone took me to an old post sorry for bring it back up.
JBH
Elora has a set of ball Torx keys that work well. I bought them from Amazon I think. I think they are made by a company called HaFu. Based on the holder design I think they also supply Hazet and VBW.
I really like and recommend Bondhus double-ball stubby hex keys, too. They demoted a Stahlwille set to the lending drawer.
