L5wolvesf
I figure y'all can easily answer this question. I'm planning on running a couple additional air lines and have a couple steel Lincoln quick disconnect fittings. Problem is one is stuck - the part that should slide back to disconnect doesn't move. Since I don't know what is inside I'm not sure if I should try soaking it in PB or something similar. I also don't know if it would come apart easily to clean it up or???
Thank you
Thank you
