Sub Panel from a Sub Panel
Steve from Socal
Hutchinson Ks.
I am in the planning stages of wiring my machines in a space that has no heavy power near by in the building. The main panel is roughly 200 feet to the area and there is a sub panel about 80 feet away. The sub is 200 Amps 480 volts. I have 9 machines that can run 480 and one machine that would be difficult to change from 240, that one will be on a transformer.
Using the two highest consumers as a worst case I have an 85 amp load with a 125% rating on both. I was thinking of running a 100 amp feed from the sub panel to another local sub panel in the space where the machines will be. In addition to the machine worst case I will have a 15 KVA transformer to provide low voltage for my one machine and, lighting / wall receptacles.
Is this good practice or am I overlooking something?
Steve
W-Cummins
Iowa
Should work fine. What's your electrician say about it? Of course your going to have another main breaker panel running off the transformer right?
William....
Steve from Socal
Hutchinson Ks.
Yes,
I will have a panel off the transformer. As far as an electrician; I am doing most of the work myself. This is kind of a temporary set up in space that will eventually become offices. The space where the machines will ultimately go is being rebuilt with higher ceilings, crane and new floor.
Steve
