My parents have a 200amp main panel and there used to be a 100amp wire feeding the subpanel in the garage but they renovated the kitchen and the electrician suggested to have a subpanel installed in the house as the main panel was full, so I looked at his work and he took the 100amp cable going to the garage and cut it and used it as the feeder for the 100amp kitchen subpanel and then added a 40amp double pole breaker to feed the garage. Everything was fine in the summer but when winter came around and electric heat kicked in, the 40 amp breaker started to pop sometimes. So I was wondering, would there be a way to restore 100amp service to the garage? I guess a 100 amp subpanel cannot feed another 100 amp subpanel? Unless some circuits were moved from the main panel to the subpanel to make room, then we could lower the kitchen subpanel to 60amp, and use the 100 amp just for the garage if we run a new wire? I am not sure what total load is allowed to be.
