legotech7
I would like to add a sub panel to my detached garage. I searched here in the forums but could find anything specific to my quandary.I have a 200 amp disconnect that sits next to my meter. Can I tap into the disconnect to connect the sub panel? The disconnect panel has two 40 amp breakers in it. I believe one is for a heat pump, and the other is not marked. What size wire could I use as the feeder? The garage is about 100 feet from the house and was thinking of using 2-2-2-4 aluminum to connect them. I will be adding 15 and 20 amp breakers to the sub panel for lighting and to power some tools. I'll be running and air compressor and a small welder. None of witch will be running simultaneously. The 100 amp sub panel will have a 80amp main breaker. Here are some pics of what I am referring too.... The third one as you can see has more room for breakers, hence the question, is this possible.
Any help with this is greatly appreciated. Thanks Joe....
