23 CHIEF
Does this panel look like it's set up right for a detached garage subpanel I am gonna us the bar that's bonded to the panel for ground
I'd move that Lug to the other buss bar. Your ground wire will be smaller than your neutral.. I'd rather have more room for neutrals than grounds you can put more than one ground wire under a screw (the instructions say how many and what size). But you can't put more than one neutral in (double tap). Otherwise Yes looks OK to me. others will chime in I'm sure.
I'm Curious sberry why use the smaller bar for neutrals?
Disclaimer I'm not an electrician.
Remove the bond strap. You should only bond at the first panel. Then keep your grounds and neutrals separate in the sub panel.
Chris
I think I will move the lug or not even use it I'm using 6-3 uf and the conductors fit right in the bar
