Suggestions needed on defunct building
jollygreengiant
Ontario, Canada
Lots of suggestions here for a generator, and that's likely your best short term option. But one thing to keep in mind with that, what is your neighbor situation like? That could easily create another problem if you have neighbors close by.
maxpower_hd
Massachusetts
If the original power is 3 phase then feeding the panel with a generator may be harder and more expensive. You may need to start with some kind of 120/240V panel separate from the original setup. I looked into generators for my welding setup. A 5500 watt was only just big enough to run my welder and too small for my plasma cutter. I think it would run my compressor without any issues. The welder generators are nice. We have a Hobart at work that puts out 10000 watts. I have run my plasma off that no problem. But they weren't cost effective for me since I already have a multi process machine and didn't need it as a welder. I did the math and 8500 was going to be the minimum to run what I wanted. Volts x amps = watts for usage then I read somewhere to add 10% at a minimum to account for start up. And try to consider everything that will run at any one time.
You said they wanted a business in there. You could start a business buying and selling parts...it's free to get a federal ID number. And who says you have to actually make any money?...lol
Heat and water would be my biggest concerns. I would want at least heat before winter.
mcj115
Hershey PA
First off...that building is beautiful! It looks like a great project.
Call me crazy but I would go a slightly different direction for temporary power. I would find the local construction auction near you and bid on a portable light set. When you need power, tow it outside the roll-up door and fire it up for power, you can also tilt up the lights to use it for lighting in the shop. When you are ready to leave, wheel it back inside, it should have plenty of power and is made to run for longer periods.
When you are at the auction you could also keep your eyes open for a water buffalo trailer so you could have some water when you are onsite.
Old Man Roger
Palm Coast Florida
At the risk of being too nosy, I have to ask “ why buy a place 3 hours from home?” As to hail and solar panels, NPPD ( Nebraska Public Power District) lost an entire solar field to hail in Scottsbluff last summer.
That was my first thought, why so far away? It is a cool looking building though.
A
adtarr
@stingry Old Man Roger I am originally from that area and have a lot of family over there. My mom is also 30 minutes away so I am over there on a regular basis. To buy that in Colorado would have cost me at least 10 times what I paid for it as well. Here in Colorado I was also paying $500 in storage....now my storage bill is zero and I have more space than I ever dreamed of. Being 3 hours away is not ideal.....but it works for now.
72Anthony
Houston, TX
I'd look into getting some type of temporary power (T pole) from the utility and internet access for some security cameras, basic alarm system, and maybe motion activated lights.
Vacant buildings tend to attract vandals and storing cars and tools may attract thieves.
CraigStu
Blacksburg, Va
I think that a generator can provide power for you to do some work for sure. But I would also be talking to the power company about what they can do for you on a minimal basis. My reasoning for that is that you can learn about more than just about the minimum while talking to them. What can they do for more permanent use? What might the cost be? How to coordinate between the power company and an electrician? My concern is you get too far into a temporary solution, make some other building upgrades, and 2-3 yrs from now find out that fully powering up the building will cost $50,000 or more. Then will it be time to bail out, and lose whatever $ you have spent, or would $50,000 make sense? It would be nice to have a feel for that now rather than later. And to talk to the power company you will likely need to take a day off work so you can meet the rep. They probably don't work on weekends so that will take a bit of planning.
Fixr
SW VA
Pure spit balling here: Most places I've lived the utilities will provide a "construction" power connection for reasonable cost. It may be just a temporary pole with a couple of 120 volt receptacles attached to it. No connection to the building, just run extension cords inside. Probably requires a building permit, but very few localities seem to want generators running for the duration of a construction or renovation project. Maybe you could present an informal plan for an essentially one-man light cosmetic renovation (mostly clean-up and paint, with eventual new electrical ) of the showroom area that is visible through the big front windows, or something like that that will take several years and potentially become retail space. As long as the property is getting improved, even slowly, the town might go for it. The alternative is that the building continues to deteriorate. And as long as the showroom looks good, they may not care as much about the rest of the space.
finn
The UP, God's country
Building permits have a set time duration before they expire. Municipalities aren’t keen on never ending rehab projects.
The permits are typically renewable, but not in perpetuity.
Jagmandave
Overland Park, Ks.
I agree, very cool building and well worth saving/improving. I think it's every guy's dream to have a cool workshop like this.
Security probably isn't a big worry, but as soon as there's activity there it can become a problem.
Fixr
SW VA
That's why I suggested limiting the initial scope to cosmetically improving just the highly visible showroom area over several years. Makes it look nicer just passing by and improves the vibe of the neighborhood. Could maybe accommodate small-scale retail of some sort without having to bring the entire building up to current commercial code all at once. And the OP could likely use the unseen back rooms for shop projects and storage. Obviously, these things vary wildly from one place to another, and times change, but I have seen a few cool old buildings brought back to usefulness a bit at a time. That said, I'm certainly no expert.
walta
Dutzow Missouri
Looking at generators I can feed to a panel and wire up some permanent outlets and lights.
I think connecting a generator to the existing wiring would be a mistake as any electrican will see you work as a complication.
First order of business is to get someone to put new power lines from the pole down to new meters.
That is simply not how it works. The power company never installs the meter without approved panel in place.
Seems to me this building should have 208 volt 3 phase power about 400 amps maybe more if there is no city gas for heating.
I am sure there is a licensed electricians working in that country. You need to get reconnected with the locals and find them.
Since the building is likely zoned commercial you may not be legally allowed to sleep there.
Walta
nadogail
Coronado, CA
When dealing with the Locals, keep in mind that you can catch more flies with Honey than you can with Vinegar.
Be nice and respectful because they have the Home Field Advantage
Steve from Socal
Hutchinson Ks.
Walta
If you would have read the entire thread, the building had 120/240 single phase service at one time. Single or three phase is not the issue it seems that the panels in place are unsafe. He got a bid from a local that sounds like they didn't want the job.
Several suggestions have been mentioned to install a minimal new service. As far as single or three phase, the monthly charges and demand on three phase service really don't make sense for this buildings intended use?
walta
Dutzow Missouri
I did read the thread and disagree with the idea of installing an inadequate service in order to lower today’s cash outlay. I say put in a service reasonably for the size of the building spend the money once and not waste money upgrading every time your plans change.
Walta
Norcal
That building had 3Ø service, would not be surprised if the A/C units were 3Ø, as they should be if three phase was available.
finn
Walta
If the building is being repurposed as uncondition storage and a small one man shop, the electrical requirements are going to be substantially less than if it is going to be a fully air conditioned manufacturing facility.
I doubt if a dealership built in the fifties or sixties had any air conditioning, for example. Why would he need air conditioning for dry storage, or even 220 service for most of the building.
Another example of the old “buy once” mantra pushes the entire project out of the realm of financial practicality.
Hooked
League City, Texas
I simply want to say what a cool building you have there and hope you can work things out to make very usable for your immediate needs. Good luck.
A
adtarr
Sort of an update.....I have a meeting with the city in April to discuss a couple options for renovation/restoration grants. I do believe they will want some sort of business to be installed in the building at a minimum a retail space in the front. Will know more after the meeting.
PoorUB
Fargo, ND
Strange that they can force a retail space. Are they willing to give you a tax break or some other incentives?
What if some commercial enterprise came along and just wanted warehouse space?
Fav Onefour
MN cold and hot
I think that is based on money available for city development. It makes sense if they are trying to bring some life back to the town.
I'm sure if someone wants to do the whole works on their own dime, the building can be a warehouse.
Tundra1
Really a cool looking building and project! Any chance one of the neighboring businesses would let you bring over and plug in an extension cord for the weekend work? It would save the noise and hastle of a genset. Could pay them a bit for the electric cost but still far less than a monthly electric bill.
Uncle murph
Harford county
I would suggest that EVERYONE needs a portable/generator welder, right??? Look for one like a Miller Legend that runs at 1800rpm and it will use a LOT less fuel than, say, a bobcat. I have a bobcat, it was cheap, it does what I need it to, but it screams it's head off at 3750rpm and is fairly thirsty. No complaints for the $440 I paid for it, but I do keep my eyes open for something else.
I have the same Northern Tool Generator mentioned above. It works good. I use it to charge batteries in my garage power system right now, it has served our house when needed too. I live full time on solar/off-grid. We don't mind it, but it will not likely be a cost saving move for you, it would be an entirely dead end investment in your case. That begin said, fully off-grid right smack dab in the middle of town is becoming more common these days. Power service ain't cheap. We are on solar because bringing power in would likely cost us $50 g's.
I’m not sure thr screaming generator wouldn’t be to his advantage,” it’s only temporary until I can get my power turned on “
mcj115
Hershey PA
As others have hinted at if the city wants a retail business are they willing to back that up with tax credits grants or other value to you? As you want the building for the garage/shop, would it be possible to rent only the front showroom area out to a retail business? Ideally something low overhead with a low cost of entry....such as an antique or consignment shop? where you may be able to find someone local who would want to operate their own business a few days of the week? This way you can keep the shop space in the back for your use, collect and credits or grants to improve the building overall. You can then write off the improvements to the building on your taxes since it would be a business loss since you would be renting out the front.
If the city wants retail and doesn't back it up with any money ( credits, grants, etc). Well then the heck with them and use the building as you see fit as long as it is within any zoning compliance.
A
adtarr
@mcj115 That is what I am going to discuss......putting a retail space in the front that will be fixed up using tax credits/grants and the back warehouse will remain the garage/shop. The retail space would just be leased to a local looking for a retail space and I would not be involved in any of that....other then getting the rent checks and keeping the power on. Which fixing the power up front means the rear gets fixed as well. Ill know more later in April after the meeting.
Fav Onefour
MN cold and hot
I bet the city would love to have the front used as space that contributes to the community. It's better yet when a private owner is willing to do the work on a good building.
Empty buildings don't help no matter how good they look.
It may help to plan the front space as a percentage of the building. I wouldn't bring up the idea with the proposal, but know the numbers if they ask.
Electrical can be done with two functions in mind as well. Separate metering with full wiring in front will be needed off the bat. Have the numbers ready for that question. There are multiple arguments for adding basic service to the back portion at the same time. You can scale the install expenses by doing main service to both in one step. Having power in the back section will help with refurb projects.
It will be easier to put in good panel service in back right off the bat. That would give you basic power and allow you to finish the space later without redoing the whole works.
stingry
Western Nebraska
Out of curiosity, I drove thru Bayard on my way back from Omaha Monday I was shocked to see how much it has deteriorated since I was there last. How sad! This was once a thriving community here in Western Nebraska. Most small towns here have declined but this community has really suffered. For those who suggested you could rent part of your building for retail space, I’m guessing that 60-70% of Main Street buildings are vacant! Not a big demand for retail space.
Any luck on solving your electrical dilemma?
