I managed to let the slabs dry for four full days before I couldn't resist looking. Needed to grind the top which is really the bottom. Had some slumping due to the support bending under the weight and I couldn't seem to get it back perfect. Highly recommend having a bundle of shingles on hand for this leveling as well as seperate go the slabs from the table. This diamond wheel goes on a normal grinder and takes off the high spots quickly. Forty bucks at hd .
Also ground down tops of rails to get the clear. Blue tape over the screws is a great tip to make removing easy
Drum roll......
http://images.tapatalk-cdn.com/15/11/11/0d40d7304b73b7bfe64eb3f13c6744ec.jpg[/IMG
Hell lots of pinholes....
[ATTACH=full]1238410[/ATTACH]
[ATTACH=full]1238411[/ATTACH]
Flipping over the two smaller pieces clearly showed the drier mix vs the wet one.
[ATTACH=full]1238412[/ATTACH]
[ATTACH=full]1238413[/ATTACH]
I knew there would be pinholes but this is more then I expected. The piece with the bowl I hit with some hand sanding with 400 grit paper and it felt like soapstone.
Here's the bowl vision
[ATTACH=full]1238414[/ATTACH]
[ATTACH=full]1238415[/ATTACH]
And the square recesses
[ATTACH=full]1238416[/ATTACH]
Hmm what fits there....
[ATTACH=full]1238417[/ATTACH]
Perfect! Now with some water on it
[ATTACH=full]1238418[/ATTACH]
