tyrenta
Hi all -- I have a 1940's post/beam garage with a sagging ridge beam and I'm concerned about the blizzard coming tomorrow in the northeast. Supposed to get up to 12" of snow mixed with rain so it will be very heavy.
I was planning on finally (after thinking about it for 2 years) getting it corrected this spring by jacking the beam back to as straight as possible/pulling the walls back in with come-alongs and adding rafter/collar ties to hold it. I've meant to do this for some time but have been held up by a non-supporting 2x4 beam that runs centerline to support the garage doors -- it prevents me from getting a post directly under the ridge beam. See pics and my original thread here: http://www.garagejournal.com/forum/showthread.php?t=295089
Here's my question: Would a temporary home made poor man's scissor-jack work? basically bolt a few 2x6 together at one end with a single 1/2" lag bolt, scissor them apart, and place the v-joint under the ridge beam (essentially making a tent structure with the beam at the top), and then pull the bottom ends together with a come along just enough to bear some of the load.
If I did 2 or 3 of these would the 2x6 with a bolt be strong enough to bear the snow load if needed? Hopefully my description of what I want to do is clear enough -- essentially turning my ridge beam into the top beam of the worlds largest temporary saw horse......
