Surface Mount Romex?
RM209
MD
I’m mounting an outside light on the utility room that’s attached to my house.
For unknown reasons, the previous owner covered the inside of the utility room w/ Duroc cement board, making it difficult to run the wire inside the wall for the last 3 feet. I can cut the hole to mount the box, but wanted to avoid tearing up the Duroc to drill holes in the studs and fish the wire along the wall.
Is there a way I can mount the Romex to the Duroc safely while meeting Code? Is there a product I could use, perhaps something like Wiremold? I’m not concerned w/ the appearance of the utility room, as it just holds the hot water heater and boiler; my concern is safely running the wire.
Thanks,
RM209
mrb
use a long flex drillbit to drill sideways through the studs behind the duroc. (dont forget to attach something to the end of the drillbit to fish the romex with before you pull it back through)
R
RM209
MD
Unfortunately, that last 3 feet includes manuevering around a corner.
It adds to the complexity, but if that's the easiset way, I guess I could try a flex bit.
Thanks for the suggestion.
RM209
