Swanny1953
While I had the dash apart, I noticed empty receptacles for under dash courtesy lights. However, given the construction of the custom interior, there was no place for them to mount and be effective. An internet search yielded some courtesy lights for classic Mustangs that mount in the fairing behind the rear seat. Using a little CAD, I was able to determine the proper placement of these lights in the kick panels where it wouldn’t interfere with the speakers or the behind-panel bulkhead framing. I wired in a switch as this car will spend some time at car shows with the doors open and didn’t want to drain the battery each time it’s shown. I’m happy with the way the courtesy lights turned out.
In the course of working on the brake issue, I also discovered a fuel leak at one of the bulkhead AN fittings. Despite multiple efforts trying to rehabilitate the fittings, I ended up just getting new bulkhead fittings and having new high pressure hoses with AN fittings made to replace the leaking units. Problem solved.
Prior to attacking the braking issue, there were a couple of other items I had to address. In order to pass inspection in TX, the horn has to work. While the car had horns, and they did work, the design of the steering wheel and mounting of the horn button resulted in it being grounded all the time. Horns typically work by completing the ground in the circuit when the horn button is depressed. I had to come up with a solution to mimic that condition. I’ll admit there was a little “red neck engineering” involved, but I was able to devise a solution that completed the ground only when the horn button was depressed.
The car was also built with a killer stereo system, but not much of it was working when I received the car. From the build pics, I was able to determine the head unit was mounted under the driver’s side rear window, so off I was again tearing the interior apart to access it. I was able to install a Bluetooth adaptor so I can play music from my iPhone through the system. I also found several speaker leads were disconnected, and the fuses in the amps for the subwoofers were shot. Now that all the speaker leads are working properly and the fuses have been replaced, the stereo works great!
There were 2 remaining issues that I have to address (well, at least that I know of). On the first drive to a group dinner after getting the brakes fixed, my buddy following me informed me that I had no brake lights. I suspected I either had a blown fuse (requiring pulling out the lower dash valance again) or a pinched wire in the truck, requiring me to tear the trunk apart yet again (I’ve had it apart and back together multiple times working on the gas line issue) or both. After tearing the trunk apart, there were no apparent pinched wires, but no voltage to the taillights when the brake pedal was pushed. Also, the fuse was intact. I removed and adjusted the brake light switch and everything is back to working as intended.
The last issue is a gas smell in the passenger compartment that I have to track down. I thought I had a fix for that as the fuel filler area wasn’t isolated from the passenger compartment and the fuel filler has a flap valve like on newer cars. After caulking around the filler neck, the smell persists, so I have to tear the trunk apart again to try and trace this down.
Lastly, while working on the rear lighting issue, I did a search to see if there were any “blue dot” replacement lenses for the lights on this car. To my delight, there were, and now they are installed. I really like the effect of these lights.
