Switch Requirement for Ceiling Fan
matt_i
So I have a ceiling fan with remote control. It has no light bulb section.
I wired 120vac to it, it works perfectly, on, off, 6 "gears" and reverse.
But I have no wall switch, seems like I am doing something wrong. I can still add this but I'm closing in on hanging the first sheet of drywall....so.....
Is there a code requirement to have a typical on-off wall-switch to control the ceiling fan?
PCustoms
VT
Not sure on code, (don't think it is required) but how the heck do to turn it on? What happens when the remote **** out?
For the record, all mine have 2 switches, 1 for light and 1 for fan. Would rather have the convenience, even if I always level it "On" and use a remote.
matt_i
Yes, I thought of "future needs" for another replacement fan (someday) without a remote. Probably not a light but why not run the 14-3 while I can.....
MrSurly
East Texas
Code requires (if I recall correctly) each “lighting outlet” to have a wall switch article 210 I think... and I think the box where the fan is would be considered a lighting outlet, whether a light is currently there or not.
Edit: I’m wrong, it looks like 210.70 says “at least one” lighting outlet needs a switch, but not all, so maybe it’s good?
PhysicsDude
Dallas, TX
Some newer fans recommend not switching power on and off from a switch, they're intended to be only controlled via the remote control.
Quite a nuisance if you ever have problems with the fan, but its how all my ceiling fans are in my house currently.
Bert_
NW Iowa
I'd at least put a wire and box in the wall. Blank it for now but it will be there when you need it. I am not a fan of the remote control ceiling fans.
dogdog
I dunno about code, but I put a switch on my ceiling fan even though it have a wireless remote. Just in case I needed to service that thing or lost the remote etc.
slow
near Orlando
I second, a double box and a 14/3 run to the fan would be how I would handle it on my house. Even if you don't put 2 switches on the fan for now, I personally hate remotes and want to have a switch for the fan and light at the door.
