Switching motor from 220v to 110v
AR-Trvlr
Chamblee, GA
My father gave me some of his tools as he downsizes. One is this Grizzly band saw. He was running it on 220v, but I need to switch to 110v. It looks like it’s fairly simple - just follow the diagram. The wires are numbered, so move the to the positions shown. Am I missing anything?
Also, when I wire up the plug, which wire goes to which post? The green is ground, but the other two?
pattenp
Virginia - USA
If the on/off switch is single pole then make sure it's switching the hot side. If the switch is two pole then it doesn't matter.
Norcal
Honestly to be done correctly it needs a 30 amp circuit on 120v. There's a good chance it will trip a 20.
Only reason that it might not trip is because it’s a bandsaw, but being of ChiCom origin who knows.
