[FONT="]July 1, 2010[/FONT][FONT="][/FONT]
[FONT="]Can not manufacture or import non-qualifying T12 ballasts (magnetic) even as replacement ballasts that operate full wattage or energy-saving [/FONT][FONT="][/FONT]
[FONT="]4-ft. T12 medium bi-pin RS and that 2-ft. U-lamps that operate on the same ballasts[/FONT][FONT="][/FONT]
[FONT="]8-ft. T12 Silmline IS[/FONT][FONT="][/FONT]
[FONT="]8-ft. T12 HO RDC [/FONT][FONT="][/FONT]
[FONT="]Exceptions[/FONT][FONT="][/FONT]
[FONT="] Ballasts that dim to 50% or lower[/FONT][FONT="][/FONT]
[FONT="] Residential only low-power factor ballasts[/FONT][FONT="][/FONT]
[FONT="] T12 HO that start down to -20 degrees F[/FONT][FONT="][/FONT]
[FONT="] [/FONT][FONT="][/FONT]
[FONT="]January 1, 2011[/FONT][FONT="][/FONT]
[FONT="]EISA 2007 Can not manufacture or import today’s 100W line voltage, medium screw-base general service incandescent lamp in CA and NV[/FONT][FONT="][/FONT]
[FONT="] Replacement can be no more than 72W[/FONT][FONT="][/FONT]
[FONT="]July 14, 2012[/FONT][FONT="][/FONT]
[FONT="]2009 DOE Lamp Rulemaking standards effective for IRL and GSFL[/FONT][FONT="][/FONT]
[FONT="] Covers reflector lamps greater than 2.25 inches in diameter, 40W-205W, line voltage, medium screw-base[/FONT][FONT="][/FONT]
[FONT="] Can not manufacture or import today’s standard halogen lamps; replacements likely to use IR technology and/or other advanced technologies[/FONT][FONT="][/FONT]
[FONT="] Maintains the IRL exemptions established by EISA 2007[/FONT][FONT="][/FONT]
[FONT="] BR30, BR40 and ER40 lamps rated at less than 65W[/FONT][FONT="][/FONT]
[FONT="] BR30, ER30, BR40 and ER40 lamps rated at less than or equal to 50W[/FONT][FONT="][/FONT]
[FONT="] R20 lamps rated at less than or equal to 45W[/FONT][FONT="][/FONT]
[FONT="] Covers 4-ft. T8-T12 medium bi-pin, 2-ft. u-lamps T8-T12 medium bi-pin, 8-ft. T8-T12 IS Slimline, 8-ft. T8-T12 HO RDC, 4-ft. T5 and T5 HO miniature bi-pin[/FONT][FONT="][/FONT]
[FONT="]Can not manufacture or import many of today’s popular T12 fluorescent lamps[/FONT][FONT="][/FONT]
[FONT="] Can not manufacture or import today’s 2800 lumen 4-ft. T8 fluorescent lamps as well as other T8 700/SP series lamps[/FONT][FONT="][/FONT]
[FONT="] Maintains exemptions for high CRI, cold temperature, etc.[/FONT][FONT="][/FONT]
[FONT="]January 1, 2012[/FONT][FONT="][/FONT]
[FONT="]EISA 2007 Can not manufacture or import today’s 100W line voltage, medium screw-base general service incandescent lamp[/FONT][FONT="][/FONT]
[FONT="]EISA 2007 Can not manufacture or import today’s 75W line voltage, medium screw-base general service incandescent lamp in CA and NV[/FONT][FONT="][/FONT]
[FONT="] Replacement can be no more than 53W[/FONT][FONT="][/FONT]
[FONT="]January 1, 2013[/FONT][FONT="][/FONT]
[FONT="]EISA 2007 Can not manufacture or import today’s 75W line voltage, medium screw-base general service incandescent lamp[/FONT][FONT="][/FONT]
[FONT="]EISA 2007 Can not manufacture or import today’s 40W and 60W line voltage, medium screw-base general service incandescent lamp in CA and NV[/FONT][FONT="][/FONT]
[FONT="] Replacements can be no more than 29W and 43W, respectively[/FONT][FONT="][/FONT]
[FONT="]January 1, 2014[/FONT][FONT="][/FONT]
[FONT="]EISA 2007 Can not manufacture or import today’s 40W and 60W line voltage, medium screw-base general service incandescent lamp[/FONT][FONT="][/FONT]
[FONT="]2014 [/FONT][FONT="][/FONT]
[FONT="]DOE rulemaking on fluorescent ballast efficiency finalized in 2011 becomes effective sometime this year. [/FONT][FONT="][/FONT]
[FONT="]There are other DOE rulemakings to set standards for testing for standby power for fluorescent and metal halide ballasts and we expect a rulemaking to set standards for metal halide ballasts beyond those established by EISA 2007. There are also provisions for other DOE rulemakings affecting lighting that will replace standards listed above in the future.[/FONT][FONT="][/FONT]
