Table Mat
stupidjet
maryland
i'm looking for a soft mat to work on small things, like high end fishing reels. basically like a mouse pad for a computer, but larger. any ideas where i could get one or what that material is called?
The KickStand
May be too dense, but rubber stall mats from a local tractor supply? Different thicknesses and not expensive. 4x8x1/2” around $35 here in the Midwest.
4xdog
Santa Fe, NM
The mats sold at art supply stores (and Walmart too, for that matter) that are used as x-acto cutting boards are terrific work surfaces. I have a large one on my center bench.
They're resilient, but not as soft as a foam mouse pad.
Alvin is one of the main suppliers, as part of their drafting/art offerings. Available in a range of sizes.
https://www.alvinco.com/Shop/Products.aspx?IID=32394
You can see the blue mat in the background here:
Michael_in_DE
Wilmington, DE
I bought a roll of underlayment (?) from a yard sale. Adhesive on one side and has a 1/16 of cushioning which helps with reducing bouncing parts. I guess you put it under wood flooring. Anyway, I cut a bit of the adhesive tape off and mount it to my work surface. I really like it. And when it gets dirty, I cut a new one.
rlitman
Long Island
Self-healing mats come in flat and roll form. The roll out ones have some memory, but are more flexible than the flat ones. Still, I only had luck with a roll type on my drafting table after stapling it down.
The self healing mats use multiple layers. The top layer will be a soft vinyl, that a knife can run through. This will be stuck down to a harder plastic layer that stops a knife, so that you don't cut through the mat. It works pretty well as a crafting cutting board and easily cleaned work surface. It is non-marring, so that might be what you need.
Another non-marring surface is wood butcherblock. This gets eaten up faster if you use it for cutting, but makes a great work surface.
Stuart in MN
Minneapolis
Most any department store will have tablecloth pads in the white goods section. They are meant to go underneath a tablecloth on your dining room table, but should work for your purposes as well.
Sco Deac
They may be too small but some of the silicone mats that woodworking stores sell can be nice. They pitch them for glue work because they are easy to clean, but they are nice work surfaces too.
Ign
Butte Peak ND
A sheet of UHMW could work. It's more "hard" than soft but won't scratch anything. This is what I use on my Bridgeport bench. Chemical resistance is excellent
4xdog
Santa Fe, NM
Here's an image from Alvin's website showing one of their cutting mats. It's a better photo than the old blue mat in my earlier photo.
eyeball
Google "gun cleaning mat" and just find one without the graphics. Many are exactly what you describe - oversized mouse pads.
rlitman
Long Island
Those come in all sorts of sizes. They're used as commercial baking mats, so you can get them sized to fit baking sheets. A half sheet pan fits nicely in a home oven. They're a little fragile for a workbench use though.
Mine are an oil absorbant non-woven textile mat on top of an impervious layer that prevents any spills from damaging the surface beneath.
BMack37
Don't get the ones for use in an oven, get the silicone dog bowl mat, it's a lot thicker.
928'er
Wine Country, CA
Geez, that's a big bike frame! What is it, looks to be maybe 64-66cm (or more). You must be one tall dude. :)
6PTsocket
Jewelry supplys sell various mats for just what you are describing. Fot heavier duty use Jegs has a rubber mat with molded compartments to keep track of small parts.
californiaHank
I use a pad I got from Amazon that's sold as a work mat for guitar repairmen.
The brand was "Music Nomad". They come in several sizes.
They're kind of like oversize mouse pads - a bit of grip and they don't scratch your work pieces.
Last a long time and don't cost too much - $15?
unknownroad
WNC
Costco often sells interlocking foam-rubber floor tiles, I think they're 2' square, about 3/8" thick, and you get maybe 6 of them in a pack for $10. They're resistant to any oil or solvent I've thrown at (dropped on) them, durable as long as you're not cutting into them, and kinda squishy if that's what you're looking for.
4xdog
Santa Fe, NM
Hah! That's my Alex Singer, custom built for me by Olivier Czuka a few years ago in a special Reynolds 531 tubeset. When you're the Alex Singer shop, Reynolds will do stuff like that for ya...
It's a 69 cm frame!
Most of my miles get put on my 68 cm Waterford.
And I'm tall, yes, but not *completely* out of the box. 6' 6".
nes999
IL
When I used to work for an architecture firm, we used re do the tables a few times a year. We used spray adhesive.
Sent from my VS988 using Tapatalk
NWOhioChevyGuy
Buckeye Hill (Morenci, MI)
I used to work for a filtration company that gave away counter mats for wholesale / warehouse sales counters.
Still have a pile of them - if you want to pay shipping I can send some to you.
Rickster
SE PA
Yoga mat?? They come in different types from foamy to solid and from thin to thicker.
guy48065
Calibration Lab
I get "table pads" at the local thrift store for a couple bucks. The 1/2" thick kind with felt on one side, vinyl on the other.
928'er
Wine Country, CA
It's a 69 cm frame!
Well, you've got about 10" on me!
My custom is a 54 cm Mikkelsen. A beautifully filet brazed mix of Columbus SL and SP that I built out circa '87 or so.
paulsomlo
Northern Colorado
When my jeans wear through at the knees, they become shorts. I cut the legs length wise, right next to the seams - they make for a good working surface and keep my bench cleaner. And they're really tough.
