i'm looking for a soft mat to work on small things, like high end fishing reels. basically like a mouse pad for a computer, but larger. any ideas where i could get one or what that material is called?
The mats sold at art supply stores (and Walmart too, for that matter) that are used as x-acto cutting boards are terrific work surfaces. I have a large one on my center bench.
They're resilient, but not as soft as a foam mouse pad.
Alvin is one of the main suppliers, as part of their drafting/art offerings. Available in a range of sizes.
https://www.alvinco.com/Shop/Products.aspx?IID=32394
You can see the blue mat in the background here:
They may be too small but some of the silicone mats that woodworking stores sell can be nice. They pitch them for glue work because they are easy to clean, but they are nice work surfaces too.
Google "gun cleaning mat" and just find one without the graphics. Many are exactly what you describe - oversized mouse pads.
Those come in all sorts of sizes. They're used as commercial baking mats, so you can get them sized to fit baking sheets. A half sheet pan fits nicely in a home oven. They're a little fragile for a workbench use though.
Mine are an oil absorbant non-woven textile mat on top of an impervious layer that prevents any spills from damaging the surface beneath.
How much larger then a mouse pad?
You can get large mouse pads.
35.4" x 17.3" x 0.12"
Geez, that's a big bike frame! What is it, looks to be maybe 64-66cm (or more). You must be one tall dude.![]()
When I used to work for an architecture firm, we used re do the tables a few times a year. We used spray adhesive.Self-healing mats come in flat and roll form. The roll out ones have some memory, but are more flexible than the flat ones. Still, I only had luck with a roll type on my drafting table after stapling it down.
The self healing mats use multiple layers. The top layer will be a soft vinyl, that a knife can run through. This will be stuck down to a harder plastic layer that stops a knife, so that you don't cut through the mat. It works pretty well as a crafting cutting board and easily cleaned work surface. It is non-marring, so that might be what you need.
Another non-marring surface is wood butcherblock. This gets eaten up faster if you use it for cutting, but makes a great work surface.
Hah! That's my Alex Singer, custom built for me by Olivier Czuka a few years ago in a special Reynolds 531 tubeset. When you're the Alex Singer shop, Reynolds will do stuff like that for ya...
It's a 69 cm frame!
Most of my miles get put on my 68 cm Waterford.
And I'm tall, yes, but not *completely* out of the box. 6' 6".
May be too dense, but rubber stall mats from a local tractor supply? Different thicknesses and not expensive. 4x8x1/2” around $35 here in the Midwest.
