table saw fence
pudgybear
Brooklyn Michigan
Craftsman 10" table saw, I cannot adjust the tension in the fence, as I try it will not stay secure I must use a C clamp on the discharge end of the fence, any ideas how to tighten up the fence ?
cmandp
New Jersey
Some saw fences only clamp on the front rail is your's like that? If so it might be the fence is just flexing when you make a cut. If that's the case you'd have to add something to stiffen up the fence or get a better fence.
jdewitt
Here!
You can buy or make some pretty nice after market fences. It's basically a big T square with no flex and a way to clamp it onto the front.
gungatim
west mich
should be a long threaded rod through the fence culminating with a locknut on the far end, which clamps a piece of flat stock against the rear of the table.
check if the flat stock is bent. craftsman fences are ****, or I should say, if the fence needs a rear clamp, it is ****...
seber
Deep East Tx.
In general I definitely agree but my father had a cabinet saw made in Beloit, Wi. that had a front and rear clamp with rollers on each end. It always clamped up dead solid and very square. Sorry, I can't remember the company name. It was a very small outfit. My son inherited the saw and it still lives. It would have been made around 1950.
exmaxima1
Midwest
I had a 50's King-Seeley table for many years. I ALWAYS used a c-clamp on the back end of the fence. Also used a carpenter square for every setting. That fence was total POS.
whateg01
doo dah, kansas, usa
The thing I always hate about the fences, low end ones at that, that clamp at both ends is if it's not square before you clamp it, it's darn sure not square after you clamp it. But they do have advantages, especially if using accessories that attach to the fence.
Pics of what you are adjusting that isn't working would be a good start.
Dave
