Talk to mee about this plug.
white91formula
Boston, MA
Is this a 110v only plug or could it be used for 220v also?
Prongs are backwards from my 20amp circuits... It's it just a matter of getting a new plug?
Other end is connected to a jet 1236p metal latbe i picked up. The back of the motor says prewired for 115v but its a 1981 and i dont know if i trust no one has switched it.
joe_padavano
Northern VA
Looks to me like a NEMA 5-20 rated for 20 amps at 125 volts only.
Look again. It's a 6-20. Plug pictures below are looking AT the prongs of the plug.
Horizontal blade is on the left when looking at the prongs on this plug. Nice wall plate, by the way.
W
white91formula
Boston, MA
Its a GE dual voltage motor. After downloading a wiring diagram i am fairly certain its wired for 115v.
cobratom
Whhhaat?
The Yellow Plug is a 240V 6-20P that you have in your hand.
The Receptacle is a 120V 5-20R (Essentially a standard receptacle that is capable of carrying a 20A load when using the proper 5-20P plug)
The plug and receptacle are not compatible with one another.
cobratom
Do you have a multimeter? Check if there is continuity between 2 and 5 on the motor. If there is, it is wired for 240V, if not 120V. The wiring does look like it is wired for 120V, however the yellow plug is definitely a 240V plug.
The person you purchased this from could have wired their shop incorrectly and used that plug and receptacle as a 120V 20A connection even though it 100% is not.
ishiboo
Oshkosh, WI
Whhhaat?
Think we've established that. Some people are referring to the receptacle, but most are referring to the plug. There are no 6-20P duplex GFCIs, of course... that'd be an interesting find!
As larry said, who knows if the plug was correctly used. If OP is right and it's 120v, just swap the plug out for the right plug.
W
white91formula
Boston, MA
Based on how its wired going into the motor its wired 230v. Brown is isolated. But not all of the wires match the plate.
Unfortunately non of the wires are labeled 5 or 6 and that's is actually 7 wires coming out of the motor.
I hate electricity.... Might bite the bullet and call someone
manwithtools
Lebanon, TN
Certainly looks like the motor is wired for 230V which corresponds to the plug it has on the cord. Does not seem like too much mystery here.
W
white91formula
Boston, MA
On i decided to start fresh. Based on the wiring plate posted above and the reversible drum switch on the front of the machine i came up with this wiring diagram.
Anyone have thoughts on it? Goal is to wire the motor for 110v single phase with reverable switch.
Shiftless
East Bay SFO
Whhhaat?
That's what I was trying to say when I posted last night but my browser froze up before I could continue with my response or edit it. :(
Cobratom has it right.
