Tap .400 x 28 TPI
John Timmins
Flagler Beach, FL
Does such a tap exist ? I am working on a 1946 Mercury Outboard motor, a KD-3 that is a 3.2 HP single cylinder model. Near the propeller on the gearcase is a brass removable plug to fill the lower unit with lubricant. The fill plug unscrews using a flat blade screwdriver. Here's the problem..... The screwdriver slot was so mangled, it will not hold a screwdriver, Even an impact screwdriver didn't help. Next I drilled a hole in it and put an EZ - Out and the hole yet I couldn't get the plug to budge. I have heated the part in an oven to expand the aluminum gearcase several times also. I've tried using bees wax and every trick I know without luck to get that plug to unscrew. I believe I will have to use a Dremel tool very carefully to get that plug out.
OK, finally here's my question. I have a new plug from a long time Mercury dealer. The plug is .400inch wide with straight threads that are 28 TPI (threads per inch). I have a tap and die set, but there isn't anything like a tap needed for my outboard part to chase the threads. Is there a tap out there that is .400 wide and 28 TPI ?
metlmunchr
1/8 pipe taps are very common & often come it tap & die sets .
just don't go too deep with it when tapping or your plug will go too deep & not seal
He doesn't need a taper pipe tap. He needs a straight thread tap. 1/8-27 NPS. The plug would use an O-ring for sealing. When he gets the one out that's in there now he'll likely find some hammer fisted ***** in the past has used loctite or some similar compound to seal rather than using an o-ring. FWIW, the major diameter of a 1/8 NPS thread is .390" to .397"
AdAstra
Got a thread gauge or did you eyeball with a ruler?
If it’s 28 TPI, then use a 1/8” BSPP.
If it’s 27 TPI, use 1/8” NPS.
The BSPP will also have 55deg included thread angle vs NPS’s 60, but that’s harder to see.
BarrelRoll
Alaska
PoorUB
Fargo, ND
Isn't 27 TPI NP and 28 TPI BP? That link you posted is showing 27 TPI for NP, the OP is claiming 28 TPI not 27. Op are you 100% sure it's 28 TIP and not 27?
If you try hard enough you can usually jam an NP into a BP and visa versa.
Here's my 1/8-28 BSPP tap, .384" OD is what I'm getting. A brass plug might mash the .015"
I am just going on what the OP says and perhaps he missed the thread pitch, plus thinking that 1/8"x27 straight would have been more popular in the USA than a British thread, but who knows?
Edit, 1/8"x27 I need to proof read my posts!!
RoninB4
Under My House
Propriety tooling is possible, even for something manufactured in 1946, but I'd really make a point of using a thread gauge (or even the 1/8-27 NPS tap) to identify/compare under magnification. You got one shot at getting this correct, any mistake will mean tapping new threads. It does seem unlikely that a proprietary thread would be used on something as ordinary as a fill plug when off the shelf would do. It's not like it's a component that the OEM wants to capture the sales on for a 50 cent part the way manufacturers do now.
Walkers
Cave Creek Az
Get the current plug out first, then see if you need a tap and if it is the same as the plug you have. Then, if you still have a problem get in touch with RMACK here on the board. The man is the Ace of outboard motors.
J
John Timmins
Flagler Beach, FL
Sorry I haven't been commenting since I have been away. I discussed this with Antique Ourboard Motor Club Inc (AOMCI) guy who is the National Race Historian. He was in his machine shop when I phoned him. He said the same plug was in some Evinrudes. I got out my thread guage and it is 27 threads per inch and not 28 as I originally thought.
As someone else posted above, It was probably installed with some kind of hard setting Permatex instead of an o-ring.
I am quite familiar with pipe fittings, tapered and straight. I was in the merchant marine as an engineer before I retired. On one ship I had NPT, Bsp, Jis, and Whitworth pipe thread to cuss through. I will try to post pictures of my project.
Thanks to all the replies. I believe I should order the 1/4 - 27 NPS tap.
