John Timmins
Does such a tap exist ? I am working on a 1946 Mercury Outboard motor, a KD-3 that is a 3.2 HP single cylinder model. Near the propeller on the gearcase is a brass removable plug to fill the lower unit with lubricant. The fill plug unscrews using a flat blade screwdriver. Here's the problem..... The screwdriver slot was so mangled, it will not hold a screwdriver, Even an impact screwdriver didn't help. Next I drilled a hole in it and put an EZ - Out and the hole yet I couldn't get the plug to budge. I have heated the part in an oven to expand the aluminum gearcase several times also. I've tried using bees wax and every trick I know without luck to get that plug to unscrew. I believe I will have to use a Dremel tool very carefully to get that plug out.
OK, finally here's my question. I have a new plug from a long time Mercury dealer. The plug is .400inch wide with straight threads that are 28 TPI (threads per inch). I have a tap and die set, but there isn't anything like a tap needed for my outboard part to chase the threads. Is there a tap out there that is .400 wide and 28 TPI ?
