Tape measure rant
Wrencher 160
Il
We used to match our tapes when starting a job so we weren’t mismeasuring from one guy to another
davethorik
Norka, Ohio
Surprised no one has mentioned a premiere brand...Lufkin. For decades I have been carrying a tiny 10' Lufkin pocket tape which is in daily use. Eventually they get worn out or dropped/exploded and need to be replaced. Not handy where yo need to "push" it, because it simply isn't rigid.
Lufkin a premier brand? In 1962 yeah, sure. Not in 2020.
coljar
Belpre, Ohio
If we're talking tape measures in general, I'm a big fan of the FastCap ProCarpenter series.
https://www.fastcap.com/product/procarpenter-tape-measure?cat=308
My favorite is the Standard-Reverse that lets you read the measure from either side. I've also got the Standard-Metric for when I'm bouncing between the two systems, and keep meaning to pick up the True32, which is basically metric version of the Standard-Reverse. It should be noted that the stickout on the FastCap tape measures is not good compared to the wide blade options available from other brands, so not very pertinent to the OP's original question.
Yep, I've got these and I really like them.
Downwindtracker 2
BC
Back when we had to chase the dinosaurs off the site to start work, tapes were Stanley, Lufkin and Evans. If it was a Craftsman or Starrett, it was made by Evans, they did a lot of contract work. I used all three at one time or another, tapes don't do well in rain and mud. I found I liked the Stanleys the best. And the Evans the least.
The tape I found to be perfect for working in the shop is a 12' 3/4" Stanley Powerlock II . Nice metal case. I found another one at the fleamarket so I should be good for the rest of my life. If I want more accuracy I use a rule, more accuracy, a rule and dividers.
bdbecker
Iowa
I’m not a Neanderthal so I don’t worry about how far my tape measure can stand out in its own. I use a Bosch GLM50C...
Try measuring a piece of lumber with with that and let me know how it goes.
There is a very good reason to buy tapes that have a long stick out before they break - its so you can reduce steps throughout the day, saving time and energy by not having to walk all the way to wherever you need to hook your tape. Saving even 5-6' of walking per measurement doesn't seem like a lot, until you do it a couple hundred times a day.
Laser measures are great, I have one I use for doing facility layouts, but they have their limitations. We use different tools for different purposes, and a tape measure with a long stick-out is a useful tool given the right context.
rlitman
Long Island
I’m not a Neanderthal so I don’t worry about how far my tape measure can stand out in its own. I use a Bosch GLM50C. Pretty cheap now days (I think this was under $150, cant remember).5e1409565ea205cab93eb583b0cc3160.jpg
For stuff below a few feet I am still using a few Stanley tapes. I’m still in search of a premium/precision tape for measurements under 10’ (for woodworking).
Well, the laser isn't always a good substitute for a tape, but it is indispensable for certain tasks.
As for a premium precision woodworking tape, I don't think you'll find better than the FastCat FlatBack. If you need more precision that than, you're not going to get it from a tape.
topcok88
Why didn’t you quote the rest of my statement? I’m a woodworker who uses tape measures regularly. I do not buy into needing my tape measure to stand up 22’ away. As the stand up increases so does the profile and thickness of material - not a desirable trait for my application. I would rather have a ACCURATE and PRECISE tape measure (the two works in all caps do not mean the same thing). I will concede the ability to span the Golden Gate Bridge with a long stick out tape measure as long as my measuring device meets the two criteria - accurate and precise.
bdbecker
Iowa
Why didn’t you quote the rest of my statement? I’m a woodworker who uses tape measures regularly. I do not buy into needing my tape measure to stand up 22’ away. As the stand up increases so does the profile and thickness of material - not a desirable trait for my application. I would rather have a ACCURATE and PRECISE tape measure (the two works in all caps do not mean the same thing). I will concede the ability to span the Golden Gate Bridge with a long stick out tape measure as long as my measuring device meets the two criteria - accurate and precise...
You do realize that we are both trying to make the same point, right?
Lets word it a different way... If the only fastener you ever used was a nail, you'd think a screwdriver was a pretty silly tool.
Its the same when it comes to tape measures.
For the type of work you do, a big beefy tape doesn't make sense. For the type of work a framer does, a floppy high precision tape doesn't make a lot of sense. Neither of you is wrong, you are just using the tool that makes the most sense for your application.
Implying someone is a Neanderthal because they want a tape with a long stick-out is not warranted. Not everyone is using their tape measures for high precision work like you. It does not make them a lesser being because of it.
NUTTSGT
Northern Central Ohio
Post #23 ?
jeffp1979
Really liking my neon green Komelons I have been getting at Tractor Supply, inevitably they walk off when I let family borrow them.
MikeF2316
Thornhill, ON
I have a 25 foot Milwaukee that I can extend 13 feet in the air. None of my other dozen or so tape measures come close to that.
R
rmack898
Honu Grove NE Florida
My main use for a tape measure is steel fabrication work. Working alone, a wide blade and stick out is a must.
I bought the 30' Milwaukee at HD for $14, however the first project I used it on was building a wooden fence. It held up well and was better than my Fat Max even though the blade was only 1" wide. The 30' Milwaukee with the 1.25" wide blade was $28 and I wasn't ready to spend that much.
Now that I've used the 1" wide tape and like it, I think I'll pick up the pricey 1.25" version on my next trip to HD.
Thanks for all the suggestions.
casmurbax
Wilton, NY
Is a magnet good on a tape when you are using for metal work or does it become a hindrance? I never used one with a magnetic tip on it. Obviously it doesn't matter for wood.
Also, I been looking for a tape measure that a person who is left handed(no right hand) that shows the numbers facing them, as all tapes are mostly u sed for right handed people. My friend doesn't like reading the numbers upside down.
rlitman
Long Island
I can't say I use the magnetic tapes on metal work, but they to stick to corner beads and even sometimes screws.
I seem to recall FastCap making reverse labeled tapes.
edit: maybe just half forward, half reversed:
Dave455
Sussex, England
Many choices for tapes.
Fisco (England), Lufkin (U.S.) or BMI (Germany). I own and have used all three. All good. Fisco offer metal bodied tapes if you prefer.
I must admit that I find steel tapes quite frustrating for a lot of applications, for the reasons mentioned.
Folding rules work well - there’s a reason why these traditional patterns evolve.
If I’m working at home I use a large steel rule in preference. Mine is a Fisher, made in Japan, and it’s got a nice satin finish that’s easy to read.
The last few months I’ve been using the BMI “Pocket Tape” shown. These are stripped down to the minimum, and they work superbly. You can open them out on a workpiece, take both hands off, and the tape body doesn’t fall over. Well thought out.
Bubba Fett
Eastern NC
My favorite tape measure is an old Stanley Leverlock like the one below. You can pry it from my cold dead hands. Not a fan of the Fatmax I have, which won't stay open and won't fit in my belt holster. I also like my Komelon.
--Xi62liV0RQ4-J9I_Sim2iYdLwY9qQBnHVZoEyrykczeY8SO76_ni1wEHqgyeaoVOiNKO_Q-E9_kitUlMzoh2oxvdsebmh5usUlO_MYVlRTvIw
oldwino
Sonoma County California (wine country)
There is a very good reason to buy tapes that have a long stick out before they break - its so you can reduce steps throughout the day, saving time and energy by not having to walk all the way to wherever you need to hook your tape. Saving even 5-6' of walking per measurement doesn't seem like a lot, until you do it a couple hundred times a day. .
Back when I was running a crew one of my carpenters broke his tape. I was heading to the lumber yard and offered to grab him a new one. Asked if he wanted a 25 or 30’. After a long pause he said, better get the 25’, I don’t want to walk that extra 5’.
dutchgray
Dorset. England.
I have always liked Fisco tapes, we used to buy their standard tapes by the box but I think more walked than were worn out. BMI are fine but avoid their cheaper models, I have found the blades don't last and the printing wears quickly.
Never liked Stanley Fatmax, always found them to be too bulky and they are expensive. Ordinary Stanley tapes are fine but not the best quality, but can often be bought cheaply.
redwrench60
East Tennessee
If you work in a metal fab shop or on industrial equipment don’t get a tape with a magnetic end. It’ll always be caked with metal chips and grinder shavings.
lardy1
I have a similar old folding rule. Pretty neat relic.
I will say that I spent over 30 years dependent on a good tape measure. I mentioned very early in this thread that Stanley has been the standard for me. After reading this entire thing again, there's nothing in this thread to even make me consider anything else except that Flat back. I think I'd like that in the wood shop. Thanks for mentioning it.
Dave455
Sussex, England
Yes, the Fisco’s are great. Like them a lot. I have a Lufkin that’s probably 25 years old that’s lasted well too. Taken a lot of abuse.
Interesting about the BMI. The one I’m using most right now is the “Pocket Tape” shown. I really like the design and in use it’s more like a thin steel rule. It will be interesting to see how it wears.
I have Stanley tapes that belonged to my Dad that are probably 50 years old. Metal bodied, British made, really sturdy, and superb quality. Everything that modern Stanley isn’t!
dutchgray
Dorset. England.
I should add I do have one of those BMI pocket tapes and it is excellent, it just their cheaper models (twoComp) are not great and the current cheap Stanley ones are better.
