Wrencher 160
We used to match our tapes when starting a job so we weren’t mismeasuring from one guy to another
Surprised no one has mentioned a premiere brand...Lufkin. For decades I have been carrying a tiny 10' Lufkin pocket tape which is in daily use. Eventually they get worn out or dropped/exploded and need to be replaced. Not handy where yo need to "push" it, because it simply isn't rigid.
If we're talking tape measures in general, I'm a big fan of the FastCap ProCarpenter series.
https://www.fastcap.com/product/procarpenter-tape-measure?cat=308
My favorite is the Standard-Reverse that lets you read the measure from either side. I've also got the Standard-Metric for when I'm bouncing between the two systems, and keep meaning to pick up the True32, which is basically metric version of the Standard-Reverse. It should be noted that the stickout on the FastCap tape measures is not good compared to the wide blade options available from other brands, so not very pertinent to the OP's original question.
I’m not a Neanderthal so I don’t worry about how far my tape measure can stand out in its own. I use a Bosch GLM50C...
I’m not a Neanderthal so I don’t worry about how far my tape measure can stand out in its own. I use a Bosch GLM50C. Pretty cheap now days (I think this was under $150, cant remember).
For stuff below a few feet I am still using a few Stanley tapes. I’m still in search of a premium/precision tape for measurements under 10’ (for woodworking).
Try measuring a piece of lumber with with that and let me know how it goes.
There is a very good reason to buy tapes that have a long stick out before they break - its so you can reduce steps throughout the day, saving time and energy by not having to walk all the way to wherever you need to hook your tape. Saving even 5-6' of walking per measurement doesn't seem like a lot, until you do it a couple hundred times a day.
Laser measures are great, I have one I use for doing facility layouts, but they have their limitations. We use different tools for different purposes, and a tape measure with a long stick-out is a useful tool given the right context.
Why didn’t you quote the rest of my statement? I’m a woodworker who uses tape measures regularly. I do not buy into needing my tape measure to stand up 22’ away. As the stand up increases so does the profile and thickness of material - not a desirable trait for my application. I would rather have a ACCURATE and PRECISE tape measure (the two works in all caps do not mean the same thing). I will concede the ability to span the Golden Gate Bridge with a long stick out tape measure as long as my measuring device meets the two criteria - accurate and precise...
Is a magnet good on a tape when you are using for metal work or does it become a hindrance? I never used one with a magnetic tip on it. Obviously it doesn't matter for wood.
Also, I been looking for a tape measure that a person who is left handed(no right hand) that shows the numbers facing them, as all tapes are mostly u sed for right handed people. My friend doesn't like reading the numbers upside down.
There is a very good reason to buy tapes that have a long stick out before they break - its so you can reduce steps throughout the day, saving time and energy by not having to walk all the way to wherever you need to hook your tape. Saving even 5-6' of walking per measurement doesn't seem like a lot, until you do it a couple hundred times a day. .
Many choices for tapes.
Fisco (England), Lufkin (U.S.) or BMI (Germany). I own and have used all three. All good. Fisco offer metal bodied tapes if you prefer.
I must admit that I find steel tapes quite frustrating for a lot of applications, for the reasons mentioned.
Folding rules work well - there’s a reason why these traditional patterns evolve.
If I’m working at home I use a large steel rule in preference. Mine is a Fisher, made in Japan, and it’s got a nice satin finish that’s easy to read.
The last few months I’ve been using the BMI “Pocket Tape” shown. These are stripped down to the minimum, and they work superbly. You can open them out on a workpiece, take both hands off, and the tape body doesn’t fall over. Well thought out.
If you work in a metal fab shop or on industrial equipment don’t get a tape with a magnetic end. It’ll always be caked with metal chips and grinder shavings.
I have always liked Fisco tapes, we used to buy their standard tapes by the box but I think more walked than were worn out. BMI are fine but avoid their cheaper models, I have found the blades don't last and the printing wears quickly.
Never liked Stanley Fatmax, always found them to be too bulky and they are expensive. Ordinary Stanley tapes are fine but not the best quality, but can often be bought cheaply.
