Taping ceiling joint
mark_k
Hello, I am getting ready to tape the corner joint where the ceiling meets the wall. My question is it is 40 feet long, should I tape the whole 40 feet in one go, or short segments? Thanks
Leaflessshadetree
Don't ask.
Mudding/sanding will be a little easier to do the whole length with one piece of tape. Also if that tape goes over the ends of the tape from the walls and ceiling. Is there a reason you want to do short segments?
maxpower_hd
Massachusetts
I agree. We did everything on mine in one piece, unless we ran out of tape some place in the middle of one of the runs. I did use the nylon mesh stuff that is sticky on one side so you could go along and put the tape up first. It did make it easier.
Kaizen
New England
I typically work alone and have sometimes found long pieces like that with enough weight will pull down what I have just mudded up. so cut a piece of wood and if you are on a ladder do as far as you can reach and put the wood in to hold it up till you reposition and repeat.
M
mark_k
I am working alone on it and not the best on corners so wasn't sure if it would be better/easier to do short runs over doing the whole thing with one peice.
Cyberbear
California
Depends on your skill level, but I watched my drywall guys and they all preferred the fiberglass self-adhesive tape for these situations. I suppose it's about what you are most familiar with.
M
mark_k
I was under the impression that the self stick wasn't usable for corners that you had to use paper or the corner beads for corners.
