mcdtommy23
First, you have no idea of my qualifications, I am far from a 'light bulb changer' as you so eloquently put it. ( I mean no disrespect to guys who change lamps for a living).
Second, you need to get yourself a copy of 70E.
Last, what are you going to tell your customer (or employer) when you are working something live and (forgetting about personal injury and property damage for a second) cause a fault and trip the circuit you so desperately had to leave on?
Or as an extreme example (which has happened) the GFP on the service is set low (100 amps?) from when it was first installed and you trip the GFP on the service taking the entire facility out? Take that a step further and the 2000A main you tripped hasnt been maintained and you break a spring or something when you try to reset it. Now you have a $10,000 repair bill because someone couldnt be bothered to turn a circuit off.
A scheduled shutdown is always better than an unplanned outage.
All the more reason to tape the damn outlet.
If you can't find the electrical panel then either you're a bad electrician, or you found a really, really stupid customer - and in that case, tell them you'll come back when they find the breaker.
If we tell the customer (our employer) to pull his head out of his ***. We will no longer have a job. We have urged him to have these moved as have several outside companies. Luckily we know where the panels are at and have indicated their location near the affected devices/outlets.
