Teeing off buried pvc water line
jmillican1983
Behind my house
I'm getting ready to pull a 3/4" pex-a water line into my shop inside conduit that I buried before pouring the slab. I am curious what you all think about the different methods of teeing into my main water line, which is buried about 24", and is 1-1/4" PVC. I am on city water. I understand that digging out 3 feet on each side of the main line to get enough flex to install a traditional tee would be the best method, but I am considering less labor intensive options as well. I have clay soil and I really don't want to dig that much by hand. My other utilities are very close to the water line.
Does anyone have any experience with those slip couplings that use two o-rings, extend into place, and are solvent welded on each end? I could cut a short section out of the main line, install the slip coupling that has already been welded to a tee.
How about using a regular tee and cutting the ridge off the inside to allow the tee to slip all the way over the main line, and then slipping it back over the other side quickly before the solvent sets?
My understanding is the shark bite slip fittings that are made for this type of application are only compatible with copper, CPVC, and pex, so that option is out.
Any other options I haven't thought of?
larry4406
Northern Virginia
I am thinking 1.25" PVC should be solvent welded fittings with socket type hub fittings. One slip coupling and a tee and you should be in business.
I assume your meter is out at the street and you are intercepting between the meter and the house. Is your meter accessible with easy shut off access? Have you confirmed you can reliably shut of your house and restore service so you can then cut the main to install tee? Many times meter valves that are not cycled (ie - old homes..) are not happy about moving and leak and sometimes lock up in position when tried to be cycled; not a good think to happen on a weekend...
I am thinking I would install a curb box with valve (and long handled valve key) on the tee branch outlet so you can quickly get the house back on line while this project of running water to the shop project goes south as may likely happen...
Does your jurisdiction require tracer wires? If so get the proper color (blue) and gage of wire (check the specs from the AHJ) and figure out how to do a splice. Required inspections?; obviously check this out..
Obviously obey the frost depth requirements in your location of "Behind my house"...
J
jmillican1983
Behind my house
a 4 elbow swing is your best bet you only need to dig about a foot in eah direction
Will the 4 elbow swing have a noticeable effect on water volume at the house? I have a long driveway (300 ft) and it's important to me to maintain good water volume. I have read that adding too many elbows reduces water volume.
J
jmillican1983
Behind my house
Yes, I will be teeing on my side of the meter. About 100 feet down the driveway. I plan to tee off the main line and install a shut off valve for the shop line right after the tee. I will install an irrigation box for access. Frost depth is less than the existing water line depth of 24" PEX sleeve is already buried at 24" depth, as well as a tracer wire. Thanks for your input.
