Tekton socket set case - sockets jumbled around immediately after closing and moving
techenthusiast
http://www.amazon.com/dp/B000NW9XSK/?tag=atomicindus08-20
I bought this set for my truck and the plastic blow mold case is pretty bad. It can't hold sockets in place at all and I'm not throwing it around or anything
I've tried stuffing paper in here in addition to the foam pad but its not happening
Any suggestions ? Should I look into an aftermarket blow mold case? Where can I get those?
Sent from my XT1080 using Tapatalk
blkSRT
Try using a thin piece of foam. You should be able to find at any craft store.
dede2897234
Northern, Ohio
techenthusiast,
I would cut to size various thicknesses of bubble wrap and place it inside the case until one works. I purchased a Gearwrench Vortex bit socket set that didn't come with a foam separator and I faced the same issue as you. The bubble wrap worked for me.
Dave
unslow1
Illinois
I just cut a piece of regular cardboard to put inside mine. It's been working for going on 20 years.
toolmutt
Texas
I cut-to-fit a piece from an old closed cell foam sleeping pad used for camping. You could find a cheap one at Walmart.
Sanny81
New Jersey
You could try cutting some drawer liner to size and see if that helps. Might take two or three pieces but the grip on the drawer liner might help more than foam.
Fedwrench
Valley of the sun
As others have suggested bubble wrap or cardboard might work. I would tray a cut down piece of yoga mat. It's cheap, compressible, and it won't fall apart.
Another idea would be to get 2 inch wide adhesive Velcro but, only use the pile side, and place strips on the underside of the lid. Good luck!! :beer:
