Telephone Land Line Removal?
PCustoms
VT
In light of the fact that country kids got their hands on vehicles at early ages.......
Reminds me of a grammar school science fair project I did setting up an operable vintage car ignition system on a coffee table; washing machine motor, car generator, distributor, coil, spark plugs and related wires plus the various belts to have everything running.
RDF (not me) came along and grabbed a spark plug/wire and got a fast lesson. There was laughter.
Who amongst us hasn't "checked the spark" once or twice?
PCustoms
VT
When it happens at 11 years old the lesson sticks. And we say "Grap that!"
I shocked myself twice when I was a kid. The one I really remember was plugging in the old non-polarized radio in the garage. Not really sure what happened but I sure felt it from toes to the hair on my head.
BrandonV
Arizona
Probably nothing you did wrong. Those "All American Five" radios were a shock hazard from the factory.
The majority of those radios were made of plastic to prevent contact with the metal chassis. Occasionally, someone would make the chassis out of metal, which was rare but did happen.
Even the plastic ones had metal screws that contacted the chassis on the bottom. If you happened to plug it in where the hot is tied to the chassis and touched one of those screws on the bottom, you were likely to get zapped.
reader2580
Minneapolis, MN
I've done consulting work for our former teleco and they had pockets full of money. What utility doesn't?
Lumen (formerly Centurylink) has been losing billions per year. They sold off a large portion of their landline business a few years ago.
The phone company tech that removed it told me if anything, 45 volts. But for all I know that could just be in our area on an old system.
As I mentioned he showed me a pair of non-insulated scissors and said that is what he uses.
that is standby voltage.... ring voltage is double that in AC and pulses... ive been shocked by ring voltage
BrandonV
Arizona
Yup. Ring voltage is 90VAC superimposed on the -48VDC standby.
You can get killed by the ring. Is it likely? No. Can freak things happen? Yes. A healthy person should be able to take it... but that's not any reason to test that theory.
zendriver
Indiana
The phone companies that are regulated are usually allowed to fully recover the decommissioning cost in their rates plus depreciation of their value. There is no hit to their profits when removing the hard lines.
I was referring to operating a land line infrastructure not removing it, which almost seems like a waste of time.
zendriver
Indiana
Voltage does not kill, it's amperage.
1 amp and up can kill, but a ring generates less that 100mA of current, so yah, not very likely with anyone.
AA/FC
Just for the record.... When I was a young kid, probably 12 years old, (probably 1985) I was adding a new telephone line into our new family room addition..... I was stripping live phone wires with my teeth. (which I had done a handful of times in the past) I never experienced any shock, until the phone rang at the EXACT SAME moment when the stripped wire was still touching my tongue/teeth/mouth/lips. lol. I can tell you with 100% certainty, from personal experience, telephone lines do indeed have increased voltage while ringing, AND it's not enough current to kill you, even if the wires are in your mouth. lolol
Yes, this is a true story.
BrandonV
Arizona
Correct. The point I was making is that during the ring, the combined voltages can allow a non-negligible amount of current to pass through normal skin resistance.
A healthy adult will typically be fine, but if someone has a cardiac condition, it could cause a problem. I once saw someone go into the early stages of cardiac distress from the residual capacitance in a hardwired smoke detector. Ironically, that smoke detector probably saved his life due to the follow-up, where they identified a problem with his heart structure.
I've worked with a lot of high current -48VDC powered telecom systems and I've never felt anything when incidental contact was made. Always a "shock" when someone accidently shorts something however.
Usually stories I've seen about people killing themselves with low voltage usually involve a low voltage source (usually a welder) and accidental contact on low resistance, sweaty skin on the abdomen by their heart. The biggest factor being that unlike a ring where you'd likely pull away these are situations where constant current is applied until somebody finds you cooking.
sparky 1971
Central Iowa
About 25 years ago I was sent to a model house that had a dead phone jack that was inside a built in cabinet. I crawled in with a screwdriver and took the jack apart and saw that a wire was broken on the screw terminal. Easy fix, but I didn't have anything to strip it with. Instead of doing the intelligent thing and coming out for strippers, I did the lazy thing and stripped it with my teeth. I heard a phone ring in another room while every tooth in my mouth got rattled loose. There may not be enough current to do any damage, but there is enough voltage to be an attention getter.
BrandonV
Arizona
I used to work with a BK Precision telephone tester. I swear those bastards at the factory set the, "NORMAL" ring test to something insane. We usually found that, "LOW" was similar to what the CO would normally provide. That machine felt extra spicy for sure.
john.k
Brisbane Qld Australia
All the old engine welders were 100v DC open circuit ...........used to get a burning sensation with wet gloves ......nothing fatal ,thats for sure ...........Then the "thought -police" discovered it .........old welders all condemned ,all new welders limited to 32VDC.......and dont work worth ****.
BrandonV
Arizona
Rare but a welder can kill.
  • 0379-07382901804-2.pdf
SOMEDAY ...
Someone is going to figure out a "cost effective" way of "harvesting" the millions of tons of copper in old, now dead, phone lines !
john.k
You mean like stealing tons of cable at night ?.............one crowd had 'harvested ' a truckload of heavy underground cable ,when the cops arrived .......seems the telco had been compiling a dossier on crooked scrap yards ,contractors,and well known metal thieves for 12 months before the 'sting'............Without evidence of 'criminal conspiracy ',the courts dismiss copper theft as a petty offence and let off guys stealing $10k of copper a night.
NUTTSGT
Northern Central Ohio
Phone company doesn't come out to do anything anymore for days upon end if that.
We just cut the service line, tie it around the pole. Toss the wire in the dumpster back at the station.
PCustoms
VT
Does OSHA and the union know that unqualified firefighters are cutting and stealing phone lines from accident scenes?
I bet you don't even check if it's ringing 90V first....
NUTTSGT
We don't follow OSHA.
The Union, LOL. These are the same guys that think we should be pulling electric meters off the side of the houses yet won't change out an outlet at the station because "they're not electricians." Yet part of our job is to have a basic understanding of electricity, construction, and mechanical aptitude.
BrandonV
Arizona
I think it depends on the fire department. In Phoenix, they likely call the city, and someone is sent to fix the issue. Are you in a rural area? If there's no facilities department, someone should take the initiative to fix it themselves. Honestly, it's hard to mess up pulling a meter. Installing a meter is riskier, depending on the condition of the meter socket.
PCustoms
VT
Haha, ok.
What could go wrong pulling a potentially corroded/damaged meter from a base that may or may not be still attached to a building on fire?
PCustoms
VT
You got them cool firefighter gloves tho right? :LOL:
I do actually.
But last time I pulled the meter I wore welding gloves, face shield and FR clothing. And I only pulled it after checking pan condition and killing the main so that there was no draw.
I had previously cut the incorrectly double tapped 10 gage from the load lugs during a power outage. I could see the line was still ripped from the pole so figured I was safe.
I know a FF who pulled a meter and got badly injured. Now he’s disabled (and retired)… should never pull meters like that
PCustoms
VT
The Union, LOL.
I was sort of joking about you stealing work from the local telephone union...
Jokes aside, how are FF not required to follow OSHA?
Dad retired about 6yrs ago, I know for a fact they didn't wear much hearing protection as he's now fairly deaf.
reader2580
Minneapolis, MN
The local fire department will not pull meters due to the possibility of arc flash. They will either turn off the main breaker if they can get to the panel, or wait for the utility to come turn off the power.
I replaced my meter base just before an emergency disconnect switch was required. I decided to install the switch anyhow as I figured future electrical upgrades could require the switch.
BrandonV
Arizona
Lots of OSHA regulations have exceptions for emergency operations. Not to mention federal OSHA has limited power over state and local government agencies. So unless you're a private firefighting agency you aren't subjected to federal OSHA regulations. State and local government agencies are accountable to whatever state level OSHA organization exists which doesn't exist in all states.
FYI, an example on ladders:
Pretty much the first exception in there is:
1910.23(a)(1) Used in emergency operations such as firefighting, rescue, and tactical law enforcement operations, or training for these operations [...].
Not a firefighter so I can't say what goes on but when I've seen them respond to industrial fires lots of things they're doing look unsafe.
NUTTSGT
Exactly.... That was my point... However, there are very few exceptions to the rules.
I wrote our department policy and approved by the chief. In the event, a meter has to be pulled, full turn out gear, scba mask on air.
There's also a few guys that don't even need to think about doing it...if you get my point.
Fortunately, most of the meters locally can be turned off remotely by AEP. There's still some that can't be.
After regular business hours, dispatch will AEP if we need a PoCo guy on scene. Sometimes it can take a bit but if we tell them we need them emergency status ( call dependant) those guys usually bust their *** to get there.
We work hand and hand with them as much as we can. My hat off to the linemen.
reader2580
Minneapolis, MN
The local utility didn't have smart meters at the time I was talking to the fire chief. That would certainly make things easier for the fire department. I had to talk to the fire chief because I had questions if I had to leave walking space around solar panels on a detached garage roof. (He said no because they never vent a detached garage roof. They rarely enter a burning detached garage.)
BrandonV
Arizona
Honestly if your department is pulling meters without the utility level of PPE I'd at least invest in a few of these.
NUTTSGT
That's the thing, we don't. We get remote shut off or get the AEP crew on scene . t's been probably a decade since one of our guys pulled a meter.
While I understand the benefits of having something like what you linked, honestly, all it would do is give a few of these guys to pull the meter ...... "We have the tool to pull the meter so let's start pulling them "
There's just more to the whole situation than where we need to go. I just shake my head at times..
BrandonV
Arizona
Definitely. If you have the support of the local utility, I agree—don't touch the equipment. I'm not sure how rural or well-equipped your department is.
I've seen departments where their responsibilities, for better or worse, extend far beyond structural firefighting. Firefighters working as natural gas technicians and the water utility.
lund
The copper value might not even cover the cost of the workers removing it.
Likely for the lines going to the homes and on the homes. Phone wire has relatively thin conductors so the fraction of insulation is high.
Be careful also when you pull phone lines. Some of the older ones were lead sheathed to prevent weathering. So try to dispose of responsibly if they appear to be that type.
