terminating single mode SC fiber connectors
toplessHO
central florida
Its been at least 20 yrs since Ive terminated any fiber,
going back to days of epoxy UV cured,and hot melt glue, polishing with sandpaper etc.
I need to terminate a couple of fibers and was wondering how technology had changed since then.
cgrutt
Following. Attached video looks similar to process that you described. I think my buddy uses a different process but it may be different ends.
cgrutt
Not sure if this is same kit my buddy uses but process is similar I don't think he uses any glue or sandpaper.
T
toplessHO
central florida
when I stopped they were into cleave and crimp using optical gel.
I may need to farm this out since I dont see me doing more of this
past this project.
whateg01, OTDR?
T
toplessHO
central florida
running a fiber for communication to an outbuilding.
I have the fiber,and would like to use that to eliminate
possibility of lightning damage.
mike93lx
Richmond, VA
Using fiber makes perfect sense for that.
Terminating it yourself VS buying a preterminated length is the different part. How much cheaper was the raw cable?
Snapped-off
Indiana
$250 would get you a 350' pre-terminated cable with a pull eye on one end. May be able to find it cheaper.
Old tool guy
About a hunnert years ago i worked for a company that made fibers for scientific purposes, not communications. We melted our own glass and pulledthe fibers. Also made fused products, like the early colonoscopy scopes and secret stuff for the govmint.
Also did fancy testing. one of the benefits of fibers is that they are mostly immune from tapping into and/or stealing the signal by emf. But if you looped the fiber, some of the signal would leak out because you changed the refraction angle and you could read the signal.
T
toplessHO
central florida
my first large scale exposure to fiber was at Communicore in Epcot.
I hand picked the guy to do that part of the show/ride/attraction,
and he didnt disappoint as he only crossed 2 amongst the thousands.
This was long before any mainstream applications.
My 68 Firebird used a fiber optic light in the ashtray.
Old tool guy
Friend had a big buick, i think, like an electra, about 1974 model. Look in the rear view mirror, over the center of the back window you would see a couple of tiny red dots of light that showed the status of the brake lights. Cheap fibers.
cgrutt
Forgot about those my parents vehicles had them. I think GM used fiber for various lighting pretty extensively. I installed car stereos and other electronics for about eight years during HS and college and recall it being used in many vehicles. Black sheathing about same thickness as other wires "may" have cut one or two by accident thinking it was a ground wire LOL.
Stuart in MN
Minneapolis
For those suggesting methods and videos, note that there's a difference in how single mode and multimode cables are terminated.
T
toplessHO
central florida
nope. only difference is the connectors or splice tails since the fibers are different sizes but the termination methods are the same
FYI- i have a splicer and unicam tool kits
I still have all the tools for epoxy and buff,museum quality....
Checking unicam connectors that average $10 each,
I found a preterminated 100M duplex cable for $90.
The new transceivers said they were ST/SC but my neighbor
who suggested this pair tipped me off that they were LC.
So rather than adapt from ST,I bought a cable with LC connectors
fiber should be here tomorrow,I ll pull the cat 6 out and put the new fiber in.
T
toplessHO
central florida
Tested new fiber on the spool while connected to new transceivers
ran a speed test thru laptop.over 300Mbps down,about 20 up
ArcReactorKC
Out in the county NE of KCMO
I terminate fiber to some odd and far out devices on our remote job sites every now and then. I *used to be good at it back in the day with good tools and practices but I went almost a decade without making a termination.
I've literally been using these from amazon to make terms that have carried 1gb reliably.
and this cheapo tool kit.
https://www.amazon.com/YEDEMC-Conne...Dust-Free/dp/B08RD94WBH/?tag=atomicindus08-20
Fiber is either more forgiving now, or I've just been extremely lucky.
T
toplessHO
central florida
what speed are you paying for?
its the neighbors service we used to test my fiber and the transceivers.
I know the transceivers lit up the 1000 light so the fiber must be capable of that.
We saw no real gain when we took my "system" out of the loop on his laptop.
He claims hes seen 500mbps .
This is a 5G wireless connection via T Mobile
with my new ATT fiber I can get up to 500 down and 150 up using my tablet thats 6G wifi capable
Captain_Slow
Watch out for the pull eyes on pre terminated fiber. I wound up having to replace the one that came with mine as it wasn't well attached, and then broke.
It's fine now but was a pain to pull. Probably ~200ft with a couple of bends
the link speed light just tells you what speed the 2 devices are linked at. that doesnt mean that is what your service is provisioned for. SMF can go a lot faster than that
T
toplessHO
central florida
new fiber is MM
even at that Im happy with this if I can get it in the ground unharmed.
I went ahead and bought a new router too thats 6G wifi capable.
b-boy
Buffalo NY
I second the looking closely at the pulling eye. I bought a cable that came with a pulling eye. It was junk. It fell apart half way through the pull. I was able to piece something together using some of the parts, but next time I'd probably buy a new pulling eye.
rlitman
Long Island
Ive never seen wifi referred to in generations. that only applies to cellular service.
Yeah, it's a new-ish terminology.
Wi-Fi 5 = 802.11ac (though I've never seen the Wi-Fi 5 designation marketed)
Wi-Fi 6 = 802.11ax (on the 2.4 and 5GHz bands)
Wi-Fi 6E = 802.11ax (same as above plus the 6GHz bands)
Wi-Fi 7 = 802.11be
mike93lx
Richmond, VA
Wi-Fi 7 = 802.11be
That isn't new.
We know about the versions. They aren't referred to as #G, though
