tig
Loving following this thread Jack! Great work.
I'm simply pushing the car back and forth now -- not even starting it. If I laid boards down, I'd have to start it up. And honestly, I'm not that good a driver.Think a couple 2X10 under the wheels, which in turn are on top of cross pieces? Not very graceful, but it might work.
I saw your thread, and I feel YOUR pain -- having to cut and re-do such a big section of your foundation.I feel your pain. I took me about 3 hours. How high does the lift go?
Ha! Like most of what I do, it's definitely fits and starts. I'm out of commission for ten days as of next weekend, so there's a chance I'll get the concrete in before then and then it will be able to take a pretty good set before I do any heavy moving on top of it. But we'll see. The tiling is going to be a pain, since there will be a lot of new cuts to accommodate the gap and I'd like to find some way to reinforce the edge, at least on the lift side.Haven't you got that done yet?
The lift only goes up 36". But that works with my garage door height.
Well, it's only for my race car. The capacity is 3000# and the car weighs just a little over 2000#. But that capacity is slightly misleading -- the same table structure is used on tables with more than double the capacity, and the hydraulics on a lift table have to work on a tougher duty cycle than vehicle lifts, generally speaking.)Question: What is the capacity of the lift? And if you don't mind saying, how much did it cost?
It's a hydraulic lift table. On the plus side, it's American-made, stout enough to take regular hits from a forklift, and also (with some digging) concealable in the floor of my garage.maybe I missed it but do you have a pic of the lift? Great thread as usual.
You haven't "hurried" until you have a blow out with wet concrete all over and no one to help you sort it out quickly.
Truer words were never spoken... make that form like a stronghold cabinet.![]()
Jack what are you planning on attaching the tile to the metal table top with? Glad you going down deep to make room for shims to allow for final adjustments for floor / table top to match.
All right. Monday's over and here's the recipe: 1 oz gin, 1 oz Cointreau, 1 oz Lillet Blanc, 1 oz lemon juice, 3 drops Herbsaint (or absinthe, or pastis). Shake all ingredients together with ice and strain into a chilled cocktail glass. Garnish by dropping in a stemless Maraschino cherry.
It's just a shame that there isn't a similar cocktail designed for cars, as my 28-year-old Jeep deserves something for the work it did today, too.
First up, 1,100 pounds of concrete and 2,000-2,500 pounds of clay are now gone. It took three trips and the poor suspension on the Jeep was down very low. But all the concrete I cut out and all the clay I dug out are no longer sitting around in trash cans and tubs and the back of the poor Jeep.
Then two trips to Home Depot for 24 bags of Quikrete. These are the 90 pound bags that only Home Depot seems to carry. I wish they would have carried them for me to the Jeep.
Then I started removing tiles -- first, it was just the ones that bordered on the hole I cut. Then it was the ones damaged as I got tired and sloppy while removing the first set. Some had welding scars on them, so I figured why not. They were not easy to get up. And I've still got some work ahead of me getting rid of the old thinset.
Then... building the forms for the new pour -- which might just happen tomorrow. I've got to thank GJ-er Dan in Pasadena for the very generous loan of the cement mixer. The fact that my back is going to survive this ordeal is thanks you you, Dan.
And all of that loading and unloading and lifting was on top of some work (the stuntmen heist story is now set in the Ukraine, not the South Pacific) and a couple of doctor appointments (one for the 2-year-old and one for the pregnant wife).
I'm not complaining -- but it was a pretty long day.
Cheers.
(Not my photograph, but it's the cocktail I mention -- and it kind of captures the spirit of what I'm talking about.)
My concern so far has been how I'll get it out. How much adhesion is there between the wood form and the concrete?
Any suggestions?
My concern so far has been how I'll get it out. How much adhesion is there between the wood form and the concrete? If I need to make it so that a few screws will allow one side to collapse inward, I can do it. Otherwise I'll have to lift it straight up, which I've been assuming might involve a hydraulic jack or two.
Any suggestions?
Okay. The advice on the releasing the forms is good -- but it came too late. Just under 2000 pounds of concrete mix have been poured.
So, with the knowledge that this is going to be a bear and probably involve some cutting -- when is the best time to take out the forms?
Jack,
You'll have 70% of design strength in 24 hrs most likely. If you want to be conservative you can wait three days and you'll be totally good.
If you used NO form release agent....uh...contrary to what's been said above, this wood is gonna be a bear to get out. You'll have to beat the **** out of it to get it off. Just be patient (very hard) or you'll have it spalling all the edges. Did you know to agitate or vibrate the concrete? If not you MAY have some porosity or "rock pockets". Not too noticeable where you're doing this but if it bothers you, you can "bag & sack" the holes (if smaller) with straight cement and water. Let's see it after you pull the forms...if you dare!
