The 3/8 inch drive
Gmonkee
When I lightened my carry load a 3\8 drive set ranged from 1/4 to 7/8" replaced 3 drive sizes. SAE and metric abusing the equivilents of course. One ratchet and 3 wobble extensions round it out. Just the regular sockets.
And it meets my needs without making the tool bag much heavier. Getting out of diesel I was able to take out the big sizes and top out at 7/8" without sacrificing ability very much. Weight dropped from 40 lbs to about 5 in the carry bag.
arjun90
New York
You can always get a 3/8 to 1/2 adapter from Craftsman or Kobalt so that you can use 1/2 drive sockets on a 3/8 ratchet
Sent from my SM-N910T using Tapatalk
HanShotFirst
NW Nevada
I notice when I'm working on my motorcycles I'm reaching for 1/4" drive, and the rare 3/8" when things need a bit more muscle.
When I'm working on cars, it's 3/8" for most and 1/2" for the stubborn fasteners.
stihlntime
SW Missouri Ozarks
At the shop (small engine)90 percent of the time 3/8 with roto head ratchet. 5 percent 1/4 5percent 1/2.
At home on the farm more even 60 percent 3/8, 30 percent 1/2, and 10 percent 3/4. I seldom use a 1/4 unless I have too. I have xxxl hands and could never get comfortable with 1/4 drive. Due to the small size of most hardware I use a 12 volt DeWalt 3/8 impact and use a 12 volt DeWalt 1/4 impact driver loaded with a 6" long T27 bit.
BK13
PDX, OR
Mostly I use 3/8" drive; 1/4" when 3/8 won't fit, 1/2" when I'm worried about breaking the 3/8" on big/rusty stuff...
coralnut
Chicagoland
My world is full of rusted fasteners on cars.
3/8 is my go-to for light automotive work (non-brake, non-suspension). A long flex handle and a fine click stubby are my two go-to ratchets.
1/2 on a long pattern ratchet is my go-to for brake & suspension, and if a long pattern ratchet won't do it, then it's time for the long breaker or impact. I don't see any value in a standard length 1/2" ratchet for automotive work, they're too short to develop enough torque on rusted fasteners. In general 1/2" ratchets are just too heavy for general automotive work and they tend to slow you down.
I don't find much use for 1/4" ratchets except for trim panels & small engines. If and when I do bother with 1/4" I'm using a T-handle ratchet or nut drivers, not a standard 1/4" ratchet, which I think is a fairly useless tool.
For those of you who prefer 1/4 over 3/8" drive I have a question -- are you able to find extra long 1/4 breaker bars that are longer than 6 inches? That's one tool that I've been looking for that is really hard to find. Having it would make 1/4 more useful to me.
General Geoff
Allentown, Pennsylvania
The HF composite 1/2" ratchet is very handy for reassembly involving big fasteners. Not long enough to provide break-loose torque on old, rusted bolts, but for reassembly or new builds it's fantastic. Lighter than a standard 3/8" ratchet.
I usually grab the 3/8" set and a set of ratchet wrenches out of the service van first. If that won't work I'll go back for 1/4" or 1/2" sets.
kilohotel
Canada - Go Habs
I think 3/8 is the perfect drive size for 85-90% of the time, it's strong yet compact and most of the more "exotic" sockets and adapters are made for 3/8. 1/2 def. has its place for higher torquer applications.
The one I just don't get is the 1/4, might as well use a T-handler or a regular nut driver...
cgv69
Boone Co., KY
Its funny how everybody has their own way and POV.
For decades I never owned anything but 1/4 and 3/8 drive tools (except for impacts) because I never saw the need for 1/2 drive. When I came across something really tight, my 12" 3/8 breaking bar did the job (sometime with the assistance of a cheater). No real forethought or reason behind it but for whatever reason, I always grabbed the smallest tool that could do the job.
But over the years I've gotten older and weaker and now I own and use 1/2 drive stuff all the time. I just don't feel like fighting with nuts and bolts and would rather just let a bigger (i.e. longer/more leverage) tool do the work. I also broke down and bought a cordless impact wrench and driver. These days its more about working smarter, not harder.
Vigo
For me the main pro's of 3/8 are:
1/4 sockets don't go up past 14, maybe 15mm in normal sets.
1/4 ratchets couldn't handle 15+mm bolts even if the sockets were plentiful.
3/8 sockets are MUCH more compact than equivalent 1/2" drive until you get up to very big sizes at which point they are basically equal.
3/8 ratchets are strong enough to do 95% of the work i do and cover the broadest range of sizes and features.
I feel that 1/2" drive has a definite place and i have 1/2" drive sockets up to 36mm and 1 1/2", but for the most part they fall under "If you need this tool, you probably wish things were going a little better right now". Good old IR Titanium and cheater pipes are the only thing keeping me from dreading the use of those bigger sockets.
I agree with a previous poster who said that they don't see the point of any 1/2" ratchet shorter than 18". 3/8" drive overlaps a LOT with the smaller 1/2" stuff, and given the size/weight advantage, i think most people who are experienced with both would always go for the 3/8" in any situation where their capabilities overlap.
ultgar
New Jersey
Facom CDX 3/8" splined drive sockets can be used reliably to 200 ft lbs although you might have to use a breaker bar to get there......
Ratchet Guy
Richmond, BC
I use 3/8 socket mostly with a ratchet, I only use 1/4 socket with a drill as the driver with a 1/4 square to hex attachment, for 1/2 socket I only have deep impact set with an airtool, because I find that most 1/2 socket fastener requires more power to loosen one and if I use a ratchet its always tough to deal with a rusty bolt.
fatfillup
Finksburg, Md
I didn't read all the replies but in the early days 1/2 inch drive then 9/32's and 1/4 were popular here. Not sure when SO started making 3/8 drive but they had a marketing campaign to sell 3/8 drive. The 3/8 were sold with Ferret on them, for ferreting out tough to get to nuts.
zkling
Like many things it is going to depend on what the specific user commonly works on. Me, I seldom need the 1/2" or 3/4" ratchet. At that point I am usually using a breaker bar or impact gun. It seems in recent years companies have tried to push the envelope of the ratchet to almost exclude a breaker bar.
1/2 always helped me removing the oil drain plug. Perhaps, time for me to hit back the gym, haha.
:headscrat
PJNJ
Iowa
The need for 1/4 becomes most apparent when you are upside down reaching up behind a dashboard packed with wires, etc. and the only thing that can get in there is a little 1/4 ratchet and socket. Forget a nutdriver or T handle in those situations. Or underhood and there is a partial obstruction blocking the use of a 3/8 extension but a smaller diameter 1/4 extension with a smaller 1/4 drive socket can just squeeze past.
As for 3/8 drive, it was really about all I used in the '70's. My vehicles during that time were mostly early to mid 60's vintage. A lot more room underhood and under the dash. Now with manufacturers using locktite on brake and suspension pieces, you need 1/2 drive regularly. And with electronics and other things packed in underhood and under the dash, 1/4 drive is also absolutely necessary (along with S wrenches, half moon wrenches, thin profile ratchets, ratcheting wrenches, etc.).
:beer:
hangfirew8
Central Maryland
I've never thought of 1/4, 3/8 or 1/2 being in opposition or competition with each other. I can totally understand using one the most.
Back in my college days of domestic RWD cars, I rocked a new 1/2" Craftsman ratchet with shallow 12 pt SAE sockets, I fixed everything imaginable with that set (still have it). Since I inherited the rest of my tools, it was easier to find a 1/2 socket on one shiny rail when they were all consistently sized, unlike my mixed brand 3/8 set. I rarely needed the 1/4", maybe for pulling the dash or other occasional interior work.
Modern cars put an end to that. I need 3/8 everywhere for access in tight spaces, 1/2 for rusted fasteners and suspension work, and 1/4 for everything else.
I don't see the point of a long 1/4" breaker bar. It would either break fasteners or split sockets. The longest I have is an old Duro Indestro at about 6". There's a guy blowing them out on eBay right now for $8.99 delivered. Hmm, tempting.
