The 5 Stitches Garage.
ckadams00
Seattle, WA
Re: My "Shop"
Holy **** THAT is organized. Nice.:bowdown:
I love the rail anvil, and your moveable vises.
The garage door is also really great. Wow I'm gonna steal some of your organization ideas.
T
taumac
Brooksville, Fl
Re: My "Shop"
why in the heck do you own so many trimmers?
Theres only 3, 2 I use and 3rd wife or son uses when them do lawn. I drive for a living and I find blowers, trimmers, lawn mowers, you name I probably found it. PPL throw them out once the cant start them so I bring them home fix them or strip them for useful parts. Next time try to order some parts for a lawn mower or trimmer and how much ther are. Only thing for equipment that I brough it blade edger and chain saw attachment everything I found.
PEDDRO
Coburg, VIC, AUSTRALIA
Re: My "Shop"
@ XRDAD. In Florida alot of ppl have sliding screens on there garage and that what they are. It basically like sliding doors 4 panel with a track. My has what they call privicy screen you can see out but not it well sort of. Its the best thing I ve ever did for garage and at only $650- 700 dollars.
looking out
View media item 17638
That's one of the best ideas I've ever seen! I'm about to build a new garage, but it's right on the street (like 10 feet from the road!) so a solution like this is ideal to allow an open feel and keep flies out too!
T
taumac
Brooksville, Fl
Re: My "Shop"
Its works great for insects, privacy and keeps stuff from blowing in. If there one downfall it is keeping the tracks clean. Your constanly cleaning them and making sure wheels in door are moving and cleaned. I took them out for cleaning and man its a big difference without them. Its basically turn my garage to another living area of house plus it nice working out there without bugs flying around.
Randall61
Re: My "Shop"
I really like your bucket and tote system. Looks great and very Organized !!!!!!
T
taumac
Brooksville, Fl
welding table started finally
Welding table with folding welding table
View media item 17966
with folding table up
View media item 17964
right now using a pipe to keep up, I building some hinging prop that will fold up
View media item 17965
best part that I built it to roll under my floating bench
View media item 17968
still have to build a slide out shelf on bottom to house welder, O/A tanks and a 3 door cabinet I have but its getting there.
T
taumac
Brooksville, Fl
Re: My "Shop"
a few updates I redid folding hinge prop 3 times and did a sliding bottom shelf with full extension ball bearing slides. Ill use it like this for alitte then I ill finish all the welds up and paint it cause theres a few things I might add but im using the K.I.S.S ( keep it simple stupid) method on this one.
WhoWhatNow
Collegeville, PA
Re: My "Shop"
Very nicely organized shop. The table build is great! I love the design of the folding table prop. I may steal that idea.
A few questions about your mig welder. I just picked up the little brother to yours off of CL (http://www.garagejournal.com/forum/showthread.php?t=143925). I’m looking for a manual for it but haven’t had much luck. I want to figure out how to use it with gas. Have you used yours with gas or only flux core? I don’t see any place for a regulator or solenoid but I haven’t opened the case up yet. Got a manual for yours? It may be similar to mine. Thanks!
T
taumac
Brooksville, Fl
Re: My "Shop"
i dont have a manual for it but as far as tips standard tips work but cant find a replacement nozzle so a redid the end with copper pipe. Ive only used it with flux wire but friend I got it from just found regulator so I might run gas. Regulator is external and will mount to your gas bottle and solenoid is internal. There should be I alittle plastic line coming out the back in which to hook a gas line. Ill be honest with ya its a good little welder but get yourself some .030 tips and some .030 Inerrshield NR-211 and have fun. Ive found parts are hard to come by and its not worth the money in fixing up this one too much. Any CO2 regulator will work on it but I would only get it for if you really what it and use it on the next welder. This the one Im looking at to relace mine at some poin.
http://www.northerntool.com/shop/tools/product_200485145_200485145
T
taumac
Brooksville, Fl
Re: My "Shop"
Last picture why is all the wire hacked up. Your missing your wire guide and your gas line which is the clear line coming from the gromet from the back so in other post I dont know if you can even run gas now. The hose is one piece from the gun all the way to the back of unit. Again I would worry about gas but just use some .030 innershild ( flux core)
WhoWhatNow
Collegeville, PA
Those pictures were exactly what I was looking for. Thank you! Possibly the last owner modified it with a different gun. I think I will pull it apart this weekend and see what I can find. I took it to my LWS a few weeks ago and got a new new tip and some 0.035 flux wire for it. That is what was in it when I got it. I loaded the wire the other day and it seemed to run fine without the wire guide. I haven't had a chance to run any beads yet, but it did strike and arc with the new wire. For $35 I'm not complaining. Thanks again for the help.
T
taumac
Brooksville, Fl
Re: My "Shop"
I wouldnt complain either.... I weld alot of old bed frame and on the machine .35 you might have to run it on 3 or 4 2 might be too cold. I run mine on 1 and its to cold 2 or 3 is ok 4 too hot. BTW...... VERY IMPORTANT mine does and probably your does too wire feed adjust itself with heat seating. The higher the temp fast the wire speed so keep it on 5 and fine tune from there. GOOD LUCK and glad I could help out.
T
taumac
Brooksville, Fl
Im I the only one who does this!!!!
Wow.... I was just looking through the pictures I took of garage and its funny looking at it cause to me it looks messy. I decided to do some remodeling out here. I got ideas for new cabinets over main workbench and plans for 2 44 in HF tool boxes where desk is plus redo shelves in desk area plus some wiring of some outlets. This seems like the 99th major redesign since Im redo or rearranging 75% of both back and one side wall. I would redo storage wall with better shelfves but really those work ok they really would be the same except better built.
UN4GTBL
Re: My "Shop"
Wow! That is a lot of stuff, but its all very well organized!
T
taumac
Brooksville, Fl
Re: My "Shop"
I have to say its as nice and neat as it is it always seems like if I get one thing i have to make so many changes and rearranging it make it work since at some point I will park cars back in here. I got a drill press which I always wanted have to find a spot for it and build a shelf and so on. Father in law gave me a small 9 bandsaw.. have to work it in. Biggest one to date was a 8500w generator friend gave me. It needed a gas tank and frame was rusting and wiring was hacked but it work. I had to get rid of one lawn mower and build a custom frame to house it under a shelf. Just getting frustrated that nothing is simple no more.
T
taumac
Brooksville, Fl
Re: My "Shop"
I forgot to mention attic space is all used up also. Besides the usual holiday stuff I got all my camping gear, fishing gear, coolers, 3 ladders, 16 gallon shop vac, 2 workmate, chair and on and on . Its just a pia to do anything anymore just setting up to do a project is a project in itself. HOA doesnt allow sheds and Im not moving so I sit out here and think of ideas and Ive used every single space saving idea in the book to fit everything in.
T
taumac
Brooksville, Fl
Re: My "Shop"
well finally did it. I went and got 2 HF toolboxes. Cant wait to start setting them up. oh and did some other changes in garage also. Hopefully by this weekend Ill have it cleaned up enough to take newer pictures of changes.
Rezarf
Re: My "Shop"
Looks great, I really like how you've used the space in a real world garage. Thanks for sharing.
T
taumac
Brooksville, Fl
Re: My "Shop"
Theres been alot of changes at the shop, One is I finally got my new toolboxes and did alot of changes over the months on the workbench wall. I been fighting the flu this week so finally felt good enough to post some pics.... granted theres still alot of cleaning redoing shelfves and that kinda thing but heres a peek
GALLERY]
GALLERY]
GALLERY]
GALLERY]
GALLERY]
GALLERY]
GALLERY]
80WTI_55_CHEV
bundamba australia
Re: My "Shop"
Nice little setup you have,very well set out and very organised, i can't see the last lot of pics you uploaded but maybe it's my computer, keep them pics coming mate.
T
taumac
Brooksville, Fl
Re: My "Shop"
sorry guys cant get pics to posts and tried for few hours.... if interested there in my album first 5 pics. Ill try to repost when get email back for mod.
T
taumac
Brooksville, Fl
Re: My "Shop"
ok guys got some of the pics up.... like I said where new boxes are the plans for new shelfs, wall work, new shelf mounts and doing some wiring in the panel, paint etc...... and other wall been working on shef designs with wire one before a build a custom size cabinet and new outlets and electrical work..... I been fitting flu and like everything a work in progress....
T
taumac
Brooksville, Fl
Re: My "Shop"
alot of work lately... 4 complete new circiuts for garage 1 40 amp welding plug, 1 20amp just for compressor and high amp tools like saw and such 1 20amp for lights and fans and 1 20 amp for outlets. only thing running on existing circuits is frige and w/d and 1 fixture above that
this old old air return that I removed for more space
GALLERY]
this is for the pl who say clean garages dont get mess or get worked in
the mess
View media item 30425
the mess
View media item 30426
the mess
View media item 30427
shelfves going up all new support and now full acess to panel which didnt have before
View media item 30428
1 more shelf to build and make new top for boxes touch up paint and calling area finished
View media item 30429
custom/ modified old tv hangers to mount tv and computer montior off shelves and bench top. I use wireless keyboard and mouse when using computer. old labtop which feeds screen up on top shelf
View media item 30430
old shop king and nice anitque fan.... both will be painted the HF red when I find it
View media item 30431
this switch allows me to run 1 fixture in garage all the time and when needed this switch turns on other 5 as needed..... the are 8 4 foot 2 bulb fixtures it garage
View media item 30432
I call this command central. top 4 outlets switched turns on plug in lights or anything I want swicthed on bench. bottom 4 outlets live always. next to that 2 fans switch on special fan speed controls and switch to turn on off. top single switch controls switch 4 outlet while single bottom controls light in ceiling for the 1 or 6 fixtures
View media item 30433
T
taumac
Brooksville, Fl
Re: My "Shop"
oh btw..... all you might wonder why so much work everyone seems to like place so much...... well Ill say this I been wanting new boxes for years and finally settled for the HF 44s. I been needed to do electrical work for some time and with wife getting a bigger car it wouldnt fit on right ( left if looking in) cause wall stuck out to much with air return. With new boxes, new car coming and my father buying the supplies for all electrical work it was right time..... btw after all is said and done we spent $225 for all electrical supplies and another $100 for wood, drywall and misc so for say $350. I did 4 new circuits and completely rewired every fixture, fan and outlet ( btw there was only 4 in entire garage before 2 behind W/D and 2 behind fridge)and redid 1 corner in garage for $350...... oh sorry say $400 i had to buy dinner 2 nights LOL. oh almost forgot here is a pic and my truck and room made
View media item 30434
everything was pushed back 12 in which now i can walk in front of truck was before I could tailgate almost hit bench top if you look at previous pics of old area. There are 4 areas in garage..... there storage wall with totes, W/D sink area fridge, the new computer tv area, and finally the working wall.... working wall is always changing but only thing that will change there is wire shelves. Cabinets, tool boxes, top shelf, bench will all stay just trying few layouts to find layout really like which works well....
T
taumac
Brooksville, Fl
Re: My "Shop"
lol just notice on last post.....if you look closely you can still see slight shadow line on wall where old cabinets where
HSpencer
South Central US
Re: My "Shop"
You have done well, great job on electricals. I plan to move up to 150 amp service to my garage this summer, giving me 50 more amps to play with.
