machine_punk
Drilling Holes
I spent the afternoon in the shop...mostly drilling holes and finishing aluminum corner brackets.
I've been using the camera bracket I built earlier...
View media item 11682
to photograph things out in the studio. Here, the camera is 'looking over my shoulder,' which THEORETICALLY means you can see what I see, as I work. I set the camera on 'delay' and then start a function (in this case, my function is 'standing in front of the drill press') and let the camera take a picture in a few seconds. I'm not sure the action shots add anything to the thread, but it's fun.
View media item 13302
Here, I am pointing at the center mark I made for the main hole in the Fantastic Light Brackets. I made the mark for this center mark on the original paper template for these pieces and punched the center mark before I even cut the part out. It really saved a lot of trouble in figuring out where I should drill the hole later...
View media item 13303
I've been kinda nervous about drilling this hole. It is the primary function of these plates...to receive the mounting tube of my two dental lights. If these holes are drilled incorrectly, I have a LOT of machining to redo. Here is an earlier test with a scrap piece. The hole is 1-11/16ths, so I had to special order the hole saw just for these brackets...
View media item 12625
And here is my original design sketch, showing how the mounting tube will fit through these two plates...
View media item 12628
View media item 12626
Any time I want a hole accurately placed, I use a process similar to what many machinists use to accurately drill a hole. I mark the location with a fine-point marker, use a ***** punch to punch a center mark (easier to see where it is placed than a center punch), punch a center mark with a center punch, drill a center hole with a center drill (see picture below), then drill with the final drill (this is aluminum...I don't usually find I need to step up slowly through the different drill sizes)...
View media item 13304
This is one of those 'action shots.' I am drilling the hole with a hole saw. I have both the plates clamped together, so I know the hole is exactly in the same place on each plate...
View media item 13305
Viola'! Two 1-11/16th-inch holes, exactly where I want them...
View media item 13306
Here is test piece I created. A regular 'jobber length drill bit deflects too much to do this, so I tried it with my center hole drills. I'm trying to put a slot in the aluminum, like the punched slot in the lower picture. I'm going to have to figure something else out--these are really tough to do, require a great deal of hand work, and look like I cut them with a chain saw...
View media item 13307
View media item 13090
Drilling two, overlapping holes just isn't as easy as you think it could be. I'd much rather get a punch made for this slot size...I'd like to get a punch and die made for these standard rivet squeezers...I think they would have enough pressure for the 0.125" aluminum I am trying to put these slots in (they squeeze with 6,000 pounds of pressure)...
View media item 11624
I worked on a couple of other little test pieces, but I didn't get any pictures.
